Old 10-19-2015, 12:59 AM   #1
Dino451
Dino451's Avatar
Drives: Scion FRS/Whiteout/OEM spoiler
Solved:Engine rattle at low RPM
Hi I was wondering if anyone can help me. I am having a odd rattling sound coming from the passenger side at 1500-2500 RPM. After that I cannot hear it due to engine noise. It happens only when its warmed up and seems to be near the upper half of the engine. The dealer didn't do anything other than open a case with Toyota and MAY get back to me. The first time I took it they told me it was the fuel pump but I told them I know it's not because its been replaced already and it's on the opposite side. Second time they opened the case after letting them actually hear the sound since they thought it was all normal sounds. My engine has approximately 40K and have been hearing this for 3K miles. Video link below, sorry for the vertical video. Sound can be heard at the 2 second mark.
Video taken Christmas Day
[ame="https://www.youtube.com/watch?v=OFPW0OS2_5I"]FRS crankshaft bearing failure - YouTube[/ame]
I just got a call and the SA said they found a bad crank rod bearing? Ill get a better explanation later today. I think someone else on this forum had the same issue but my rattle sounded different from theirs.
Going to pick up the rental.
Edit:
I had a recent oil change(less than 500 miles ago) from the dealer and still can be heard.
Update:Update: 1/20/16 After I got it back in mid December I had it for two weeks before a even louder rattle appeared. I took it in the week after Christmas and it was diagnosed with a damaged crankshaft bearing.
Dealer said there was debris in the oil pick up and that they would order all new crankshaft bearings and that it might be ready end of the week last week.
Not sure what happened between that time but I was told yesterday I will be getting a new shortblock
Hopefully I will be getting my 86 back soon.
Whiteout 2013 FRS/ OEM Spoiler/ Clear side markers/TRD Intake/ Shark fin antenna/Rex speed blue wide mirrors/DD fog lights/Grimmspeed Strut bar/
Dino451 is offline   Reply With Quote
Old 10-19-2015, 01:04 AM   #2
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
you think too much, drive on? don't hear anything out of norm. O.o
Old 10-19-2015, 01:32 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
I hear it. Could you get the dealer to check to see if your oil pressure is within spec, at normal operating temp, of course?
Old 10-19-2015, 01:37 AM   #4
Dino451
Dino451's Avatar
I will have them check next time I go.
Old 10-19-2015, 01:38 AM   #5
Dino451
Dino451's Avatar
It's at 2 sec after the AC compressor kicks in and again at about 9 sec. It tapers off after that. I have no CEL and nothing seems to be effected other than the sound/rattle.
Old 10-19-2015, 02:05 AM   #6
Ultramaroon
not playing cards
There's another thread in which I hear exactly what sounds like excessive valve lash which comes and goes. This is a common symptom of leaky/dirty hydraulic adjusters but the fa20 doesn't have those. I'm genuinely confused by the sound.
Realistic or misguided, just wanted to explain my thinking on the subject.
Old 11-14-2015, 03:35 PM   #7
Dino451
Dino451's Avatar
I took another video of the noise which is very obvious now. It sounds like it's the port injectors but only between 1500-2500 RPM. Going to dealer next week because it's getting louder and its annoying. It's starting to make the noise now when cold and it does the startup fast revving to warm up the Cats.
Would bad injectors make this noise?
Edit: Also forgot to add that the whole car shakes slightly at that RPM range. Anything below or above that range its smooth as silk.
Old 11-14-2015, 04:34 PM   #8
Ultramaroon
not playing cards
Port injectors are way too tiny to make that heavy of a sound. Whatever it is, it definitely needs attention.
Mine does the same little dance at that rpm under no load. I think it's a resonance of the engine-transmission in the mounts. No biggie. That's a really subtle one. Kudos for noticing it.
Old 11-14-2015, 05:52 PM   #9
Dino451
Dino451's Avatar
I was really hoping it was as simple as the injectors.
I guess I didn't want to admit it haha
Old 11-17-2015, 07:28 PM   #10
Dino451
Dino451's Avatar
update:
They are going to open up the engine and check the valve train.
Old 11-18-2015, 06:27 PM   #11
acetothermus
Drives: Flying in a Blue Dream
It almost sounds like excessive valve noise. Wonder if the guides either wore out or were defective from the start.
acetothermus is offline   Reply With Quote
Old 11-18-2015, 07:15 PM   #12
Ultramaroon
not playing cards
It does sound like valvetrain noise but I'm cutting back on my speculation. I was swinging like Tarzan on a another similar thread yesterday.
Old 11-19-2015, 05:23 PM   #13
Dino451
Dino451's Avatar
Update: I just got a call and the SA said they found a bad crank rod bearing? Ill get a better explanation later today. I think someone else on this forum had the same issue but my rattle sounded different from theirs.
Old 11-21-2015, 03:23 PM   #14
Dino451
Dino451's Avatar
Crank Shaft bearing failure confirmed. Engine is in pieces.
Rattle when i turn off the engine Subforever Issues | Warranty | Recalls / TSB 11 08-18-2015 01:22 PM
Toyota/Subaru D4S "engine cover" rattle canadaRS1.0 Issues | Warranty | Recalls / TSB 4 06-14-2015 07:12 PM
Engine rattle MacJunkie AFRICA 12 04-01-2015 07:12 AM
engine rattle mrnibbs Engine, Exhaust, Transmission 11 06-05-2014 09:17 PM
Engine pinging (rattle noise) under acceleration sho AUSTRALIA 95 08-10-2013 05:52 PM
