Old 01-20-2016, 02:54 PM   #1
Ashikabi
Ashikabi's Avatar
Wheel width: autocross vs track
Did some poking but didn't find what I wanted. Just need a confirmation on: same wheel(say rpf1) same tire(say rs3): wider better for autocross, skinnier better for track? That sounds right to you guys?
Old 01-20-2016, 03:03 PM   #2
jvincent
jvincent's Avatar
As a broad generalization, yes.
Old 01-20-2016, 03:07 PM   #3
swarb
Another broad generalization would be what most people run in both situations. 17x9 +35 245/40-17.
Old 01-20-2016, 03:13 PM   #4
Ashikabi
Ashikabi's Avatar
I was considering maybe a 17x8 and kinda split the difference. I am running e85 with headers if that matters
Old 01-20-2016, 03:22 PM   #5
Ashikabi
Ashikabi's Avatar
Statement to add further detail for consideration
Old 01-20-2016, 03:25 PM   #6
swarb
What is your question here?
Old 01-20-2016, 03:45 PM   #7
Ashikabi
Ashikabi's Avatar
I suppose, would this offer any meaningful impact on performs either way or is it so minute as to be pointless and just get 9s
Old 01-20-2016, 03:58 PM   #8
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
The 9's look better, but I prefer the weight of the 8's and the broader choice of smaller tires. Narrower tires with closer-to-stock offsets feel more playful, too. As long as you get a tire with good compound, it'll be a substantial upgrade over stock, regardless.
jawn is offline   Reply With Quote
Old 01-20-2016, 04:11 PM   #9
Ashikabi
Ashikabi's Avatar
I already run autocross with stock wheels and rs3s. But I want to go to the track a couple times this year so I was looking at better wheels. Probably wouldn't get anything until I wore out my rs3s but it never hurt to learn something new.
Old 01-20-2016, 04:13 PM   #10
swarb
If you are asking these questions, your skill level is probably not high enough to notice the difference. You want to match the wheel to the tire you plan to run. Either will work fine.
I personally like to pretend I have high skill(like Takumi) so I would go with the 17x9 +35 245/40 setup.
Old 01-20-2016, 04:16 PM   #11
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
e85 + header doesn't make enough of a significant difference in power to worry about needing wider tires.
If you want to split the difference, do the 17x9 and run a 235 tire. Or at least that's what I did.
And like Jawn said, it does look better.
KevinK121 is offline   Reply With Quote
Old 01-20-2016, 04:43 PM   #12
Ashikabi
Ashikabi's Avatar
I figured it would be like that. But I don't want to regret my choice and spend more money later. I prefer to get the best tool top start with even though I can't fully use it. No point in having a handicap
Old 01-20-2016, 04:53 PM   #13
jawn
jawn's Avatar
It also sounds like you're going to be autocrossing more than tracking, so I'd be inclined to run 17x9s like basically every one else in STX.
Old 01-20-2016, 04:57 PM   #14
swarb
17x9 +35 245/40 is THE one. Don't even consider anything else. All the big boys run this size.
Spacers and Track width tnle Tracking / Autocross / HPDE / Drifting 24 10-24-2017 03:28 PM
Best Offset/Width for autocross? kuhlka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-19-2014 03:14 PM
Track width -max- Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-21-2012 06:37 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
