#57 | |
Drives: None
Sent from my LG-D850 using Tapatalk |
#58 | |
Drives: FT86
If ecu has ecutek tune in it it may prevent dealer from accessing ECU and hence he may not be able to security code system you can i believe swap out all 4 components in the security set ie dash/ecu/imobiliser and key fobs from a donour car, but if you change any of those components by themselves they need to be coded in. |
#59 | |
Drives: None
#60 | |
Drives: FT86
Probably best to talk to dealer to confirm. |
#61 |
Drives: None
I've also ordered a cam position sensor. What threw me off was that the Mitsubishi logo was on the sensor I bought from the dealer..... It is quite confusing to me. Have you ever seen the cam position sensors?
#62 | |
Drives: None
Sent from my LG-D850 using Tapatalk Last edited by Astroboy; 01-16-2016 at 11:36 PM. |
#64 | |
Drives: FT86
that cam code loks like a hard one to track down when its intermittent have a look at the Tech service bullitens it can be position sensor sensor shimming/clearance oil control valve actual cam sprocket/actuator or the ECU rom revision if earlier than B01C/D or the ecu hardware their is a long test proceedure to follow to try to isolate exact cause |
#65 | |
Drives: None
#66 | |
Drives: FT86
My guess would be if you see a large difference between intake or exhaust cams between the two banks then something is wrong.The big problem seems to be working out which component is at fault. The TSB has a complete proceedure to follow. |
| CEL P0018 Cams | woode | Issues | Warranty | Recalls / TSB | 69 | 05-13-2023 02:23 PM |
| CEL P0018 | brichard0625 | Issues | Warranty | Recalls / TSB | 8 | 02-10-2016 09:44 PM |
| 25k Miles | TimmyC | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 09-20-2015 10:16 AM |
| 2000 honda civic si 33k miles on body 3k miles with turbo kit | Anthony7515 | Cars for Sale/Trade | 3 | 07-28-2014 09:10 AM |
| Just hit 1k miles! | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 3 | 08-26-2012 09:52 PM |
