Old 01-13-2016, 09:27 PM   #15
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Originally Posted by Fenix View Post
I liked the looks and potential. I had no intentions of keeping my FR-S stock. Swapping in a built LS engine is still on the table. A C6 Corvette was my second choice when I was looking to buy a vehicle. Still might buy one. lol
I would just get a Corvette. Forget trying to Frankenstein the 86 to get it over 300 hp.
A c6 is just overall better performer right out of the box than a modified 86.
The Following 3 Users Say Thank You to Mr.ac For This Useful Post:
hmong337 (01-13-2016), strat61caster (01-14-2016), Summerwolf (01-14-2016)
Old 01-14-2016, 09:21 AM   #16
pleong
Drives: 2013 Whiteout FR-S
My end goal for the FA20 is approximately 600hp. I believe upgrading the drivetrain prior to rebuilding the engine is essential. What have you done? I ed a lot only to find myself asking more questions. Should I attempt to part something together or buy what is available?
A stronger set of gears would def be in the picture We have a group buy going for a set of straight cut gears from PAR Engineering. PM me if you're serious and want to know more. ONLY if you're serious though.
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
The Following User Says Thank You to pleong For This Useful Post:
Drakiv (02-01-2016)
Old 01-14-2016, 09:41 AM   #17
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I know two different people with ~550hp FA20's, so it's not unrealistic. A 600hp 86 will be a wacky fucking autocross car though lol. Time Attack would be very exciting to see.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 01-16-2016, 12:14 PM   #18
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
I am considering swapping the diff. FB’s kit is expensive. Mating a modified donor diff to the FT86 might be a better route.
Fenix is offline   Reply With Quote
Old 01-16-2016, 12:17 PM   #19
pleong
The diff is only part of the problem.. The trans is another weak point. More trans have blown than diffs.. But it all depends on how you drive.. I push 500+ and my trans is good.. But I'm not always on the highest map.. And I'm not ragging on it 24-7..
I bought a is300 lsd diff.. They've been known to hold up to 600ftlb according to some of the is forums I've read
hmong337 (01-17-2016)
Old 01-17-2016, 02:09 AM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The R32 rear end was swapped in somewhere in these threads. R154 may be a better option than a swapped gear set depending on how expensive it is.
Old 01-17-2016, 02:38 AM   #21
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
600hp is definitely possible but terribly expensive. So much so that when doing the math for my own build I found that it would be cheaper to do a 2JZ swap (dual ECU) than to try and build the FA20. But if it's your goal then don't let any of us stop you!
you have the option of the gear sets but another option you could look into is a transmission conversion. T56 comes to mind. I;'m sure theres plenty of engineering outfits out there capable of making an adapter for it. It's still not cheap being a one off but your'e gonna need a pretty big budget chasing 600hp anyway. It's still, however, much much cheaper than the sequential racing boxes out there.
lukey86 is offline   Reply With Quote
Old 01-17-2016, 12:58 PM   #22
Fenix
Fenix's Avatar
I believe a different engine would be a more reliable too. You would end up spending a huge fortune. The T56 would need a longer bellhousing to fit. I am starting to think an LS, UZ or JZ engine swap would be a better route.
Old 01-17-2016, 12:59 PM   #23
Fenix
Fenix's Avatar
R200 skyline r32 gt-r rear end on the brz
Old 01-17-2016, 09:28 PM   #24
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Is300 m85 diff is the best budget option. $500-800 depending on location and will hold upwards of 700tq.
Running one on my car. Long gears are awesome.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 01-18-2016, 02:09 AM   #25
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Id be excited to see another UZ swap.
.... @Manji
Old 01-18-2016, 02:31 AM   #26
lukey86
Built Not Bought
lukey86's Avatar
OP should swap a 13b rotor, verry verry cheap swap, very quiet smooth running engines, incredibly reliable, great fuel economy, you'll love it, trust me, just do it...
The Following 3 Users Say Thank You to lukey86 For This Useful Post:
Fenix (01-18-2016), flippy (01-18-2016), kch (01-18-2016)
Old 01-18-2016, 01:04 PM   #27
Fenix
Fenix's Avatar
Old 01-18-2016, 02:12 PM   #28
Fenix
Fenix's Avatar
I am ignorant about the pumpkin in this car atm. I underestimated what can be done with it. Researching IS300... DSS axles will likely be the first upgrade.
_
_
_
Drivetrain Bushings ryoma Engine, Exhaust, Transmission 7 01-08-2016 07:33 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Drivetrain slop? jordanrw260 Engine, Exhaust, Transmission 21 05-29-2013 11:46 AM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
