Old 01-12-2016, 09:52 PM   #1
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
Drivetrain Options
My end goal for the FA20 is approximately 600hp. I believe upgrading the drivetrain prior to rebuilding the engine is essential. What have you done? I ed a lot only to find myself asking more questions. Should I attempt to part something together or buy what is available?
Fenix is offline   Reply With Quote
Old 01-12-2016, 10:30 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
600hp eh? On the FA20. Well with time and money anything is possible.
You might want too look up the same trannies the V8 swap use.
Old 01-12-2016, 11:19 PM   #3
Fenix
Fenix's Avatar
It is an ambitious long-term dream. I have thought about doing an engine swap. My local tuner shop advised against it; mainly due to potential problems I would discover the hard way over time. In all honesty, I am unsure where to begin. Before dropping cash on upgrades, I am trying to pinpoint the most logical place to start. I thought about buying an OS GIKEN rear diff. Not sure what kind of torque it can handle however. The axles would give out first. ...
Old 01-13-2016, 12:01 AM   #4
ryoma
ryoma's Avatar
I think the main question is, why 600HP on this specific motor? you would probably have more luck on a higher displacement motor like an LS swap. I believe some people have already done a successful LS swap with everything working. someone even swapped over a GTR rearend onto the 86 lol. so anything is really possible, as long as you have the knowledge and funds
Old 01-13-2016, 12:22 AM   #5
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Anything over 300whp on pumpgas and you're best off with another engine/trans is what I've come to conclude.
..or better yet, another car!
hmong337 is offline   Reply With Quote
Old 01-13-2016, 03:00 AM   #6
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Your tuner advised against doing an engine swap because of potential problems, but thought nothing of 600hp on an FA20?
I would say find a new tuner.
Old 01-13-2016, 05:33 AM   #7
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
You can get a Samsonas sequential straight cut gearbox which is good for roughly 740ft/lbs for around $15,000 in the USA. Quaife also has a box that is priced similarly and good for 750BHP. Hollinger has the RD9 which is good for around 700ft/lbs and priced around $25,000.
You can also look at gear swaps. Velox has a 3rd and 4th gear billet swap which hasn't been proven but estimated to be 200-300% stronger. This means roughly 300-450 ft/lbs over stock.
There's PAR Engineering that is working with Jacks transmission to do a full straight cut dog box swap around 5-6K+ install.
Good luck with your build.
crazyfrenchbiker is offline   Reply With Quote
Old 01-13-2016, 08:41 AM   #8
Fenix
Fenix's Avatar
I never mentioned my ambitious up to 600hp target. He was throwing out more realistic numbers such as 300whp. Weight reduction, upgrading/reinforcing drivetrain weak points, handling improvements... is a start until I decide what to do with the engine.
Old 01-13-2016, 09:21 AM   #9
stevesnj
stevesnj's Avatar
So what will you need to do with potentially 600 HP ? Drifting, 1/4 mile, DD
My 2016 Build thread
Old 01-13-2016, 09:55 AM   #10
Fenix
Fenix's Avatar
> Street Legal 0-60
> Autocross
> Time Attack
I have no clue how to drift. Sounds fun.
Old 01-13-2016, 10:02 AM   #11
-Phil
Drives: Rb25 neo brz
I would just build the FA20 put a 3076-3576 on the car. Do a Velox gear swap, change out the axles and go for whatever it is your trying to do.
-Phil is offline   Reply With Quote
Old 01-13-2016, 10:05 AM   #12
mrk1
Drives: Sterling BRZ Ltd
^^^^ What this guy said, plenty of potential in these cars.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-13-2016, 11:16 AM   #13
stevesnj
stevesnj's Avatar
> Street Legal 0-60
> Autocross
> Time Attack
Hey if you want it for all that its cool but why didn't you buy a different car?
Old 01-13-2016, 11:30 AM   #14
Fenix
Fenix's Avatar
I liked the looks and potential. I had no intentions of keeping my FR-S stock. Swapping in a built LS engine is still on the table. A C6 Corvette was my second choice when I was looking to buy a vehicle. Still might buy one. lol
Drivetrain Bushings ryoma Engine, Exhaust, Transmission 7 01-08-2016 07:33 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Drivetrain slop? jordanrw260 Engine, Exhaust, Transmission 21 05-29-2013 11:46 AM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
