#15 | |
[insert cool phrase here]
Drives: BRZ Premium
A c6 is just overall better performer right out of the box than a modified 86.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following 3 Users Say Thank You to Mr.ac For This Useful Post: |
#16 | |
Drives: 2013 Whiteout FR-S
We have a group buy going for a set of straight cut gears from PAR Engineering. PM me if you're serious and want to know more. ONLY if you're serious though.
TEAM NEMESIS | NEM 86 | IG: @NEM_86 PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics The NEM86 Build Thread |
| The Following User Says Thank You to pleong For This Useful Post: | Drakiv (02-01-2016) |
#17 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I know two different people with ~550hp FA20's, so it's not unrealistic. A 600hp 86 will be a wacky fucking autocross car though lol. Time Attack would be very exciting to see.
#18 |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
I am considering swapping the diff. FB’s kit is expensive. Mating a modified donor diff to the FT86 might be a better route.
#19 | |
The diff is only part of the problem.. The trans is another weak point. More trans have blown than diffs.. But it all depends on how you drive.. I push 500+ and my trans is good.. But I'm not always on the highest map.. And I'm not ragging on it 24-7.. I bought a is300 lsd diff.. They've been known to hold up to 600ftlb according to some of the is forums I've read
| The Following User Says Thank You to pleong For This Useful Post: | hmong337 (01-17-2016) |
#20 |
Junior
Drives: a car
The R32 rear end was swapped in somewhere in these threads. R154 may be a better option than a swapped gear set depending on how expensive it is.
#21 |
Built Not Bought
Drives: 2012 Toyota 86 ZN6
600hp is definitely possible but terribly expensive. So much so that when doing the math for my own build I found that it would be cheaper to do a 2JZ swap (dual ECU) than to try and build the FA20. But if it's your goal then don't let any of us stop you!
you have the option of the gear sets but another option you could look into is a transmission conversion. T56 comes to mind. I;'m sure theres plenty of engineering outfits out there capable of making an adapter for it. It's still not cheap being a one off but your'e gonna need a pretty big budget chasing 600hp anyway. It's still, however, much much cheaper than the sequential racing boxes out there. |
#22 | |
#23 | |
#24 |
Drives: '13 BRZ
Is300 m85 diff is the best budget option. $500-800 depending on location and will hold upwards of 700tq.
Running one on my car. Long gears are awesome. |
#25 |
Junior
Drives: a car
#26 |
Built Not Bought
OP should swap a 13b rotor, verry verry cheap swap, very quiet smooth running engines, incredibly reliable, great fuel economy, you'll love it, trust me, just do it...
#27 |
#28 | |
_ _ _ Last edited by Fenix; 01-18-2016 at 02:27 PM. |
| Drivetrain Bushings | ryoma | Engine, Exhaust, Transmission | 7 | 01-08-2016 07:33 PM |
| Scion FR-S options:what options did you have dealer installed? | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 01-06-2014 01:35 AM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
| Drivetrain slop? | jordanrw260 | Engine, Exhaust, Transmission | 21 | 05-29-2013 11:46 AM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
