Northwest AK, ID, OR, WA
Old 01-14-2016, 12:10 AM   #1
stockysnail
Just the tip
stockysnail's Avatar
Nameless overpipe/downpipe welds failed and perrin endlink failed
This morning I started hearing a nasty metal on metal rattle. I was worried. After I got home from work I spent over an hour trying to figure out where the sound was coming from. With the help of my beautiful roommate assistant, and a mechanic's stethoscope, a was able to determine it was coming from the post header exhaust somewhere. I jacked up the car and saw the following:
As you can see the weld that held the resonator to the high flow cat failed and was rattling pretty loudly. The weld for the pipe of the resonator was also cracked a little.
I also had a noise coming from my front right suspension area for the last few weeks. Since I was under the car I looked around and found that the endlink's bushing failed as seen here:
I emailed Nameless to see if I could come in to get them to swap in a replacement and emailed Perrin to see if I could come pick up a new endlink. Perrin's customer service has always been stellar so I expect it to be great as always. Nameless's communication and service in the past has been hit or miss for me so we'll see how that part plays out.
We'll see if I come out with extra stuff from Perrin like a boost gauge and Nameless with a red ecu bracket and red belt covers. If they give me a special multi repeat customer discount, I just might.
Old 01-14-2016, 12:28 AM   #2
e1_griego
e1_griego's Avatar
Drives: Many
Where's the break? And was the noise constant?
e1_griego is offline   Reply With Quote
Old 01-14-2016, 12:45 AM   #3
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Yep, one of my frontpipes broke a weld there too.
Decay107 is offline   Reply With Quote
Old 01-14-2016, 01:18 AM   #4
stockysnail
Just the tip
Break was where the resonator was welded to the high flow cat. The noise wasn't constant but more dependent on the vibrations of the engine at different RPMs. I bent it out a little so hopefully it doesn't vibrate, but now I have a little hole in my cat where the weld was.
Old 01-14-2016, 06:27 PM   #5
Akari
Drives: 2013 DGM BRZ
Honestly looking at the crack I'd just have it welded if I were you. Much easier and cheaper than taking it off, shipping it back and then having to install a new one.
Akari is offline   Reply With Quote
Failed Tom's Tail lights RevoG Cosmetic Modification (Interior/Exterior/Lighting) 42 12-21-2016 06:45 PM
This is why those with failed engines need to contact the NHTSA BRZnut BRZ First-Gen (2012+) — General Topics 5 09-25-2015 09:03 PM
Failed Inspection with a tune... Shady195 Scion FR-S / Toyota 86 GT86 General Forum 19 06-10-2015 04:25 PM
Failed login notification griffinnn Site Announcements / Questions / Issues 6 02-18-2015 08:21 PM
**SOLD** F/S New Nameless 3" catted Downpipe/overpipe, Perrin Mounts Blanka Engine, Exhaust, Bolt-Ons 4 04-10-2014 10:41 AM
