Old 06-10-2012, 12:58 AM   #43
dsgerbc
Drives: BRZ(sold), STI
I do have some chirping sounds, only at idle though and I only hear it if I'm in my garage with windows down (or open the hood and try to listen where it's coming from). Give tiny bit of gas and it's not there. Not bothered atm.
Old 06-10-2012, 01:01 AM   #44
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
its the direct injection, nothing to worry about
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 06-10-2012, 01:03 AM   #45
carbonBLUE
Reverse Burnouts
Originally Posted by PERRIN_Jeff View Post
Boxers in general do not make any tapping noises. The tapping from your FA20 engine is 100% from the Direct injection injectors firing. As some have pointed out, the fuel pressure is very high and when they fire the injector, it uses 80V-ish to pull the injector open. This creates the noise you hear.
What I have found is that sometimes at idle, the DI injectors are not firing at all and its much quieter. Then sometimes is firing 100% of the time at idle. Probably a way that Subaru cleans out the engine, or tests out the cats, or a lean burn situation. Who knows for sure. This creates that noise that isn't always there. That isn't good for customers as its going to create a lot of calls to the dealer over nothing.
yeah a lot of us are just worried but folks DONT WORRY i remember my 2zz-ge celica, that was a noisy engine, sounded like it was about to rattle something loose at 8500 rpms but never did the gazillion times i took it there(was still worried every time XD lol )
(wont forget you)
2011 Infiniti G37x
Old 06-10-2012, 01:25 AM   #46
FRSCoupe
Drives: Toyota
Originally Posted by (K) View Post
Does it sound like this?
Sorry for wind noise...Everything else is normal. That was a GBS Limited at idle, iPhone vid taken right above the driver's side fender where it meets the hood.
I've read that Subies are known for that tapping, but I haven't come across any tapping from the turbocharged variants.
I can confirm this is a Toyota DI system sound, Lexus IS makes this exact sound at idle
FRSCoupe is offline   Reply With Quote
The Following User Says Thank You to FRSCoupe For This Useful Post:
Sportsguy83 (06-10-2012)
Old 06-10-2012, 02:12 AM   #47
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
That chirping noise I can somewhat hear at very low revs (<2500) in first and second gear. Like if I'm in a parking lot and going <12 mph in either of those gears (which I wouldn't be in third of course), I'll hear that chirp as I give it the throttle.
I started noticed it right after the TRD air filter drop in so I thought maybe it wasn't properly secured or something. Double checked and everything seemed fine, must just be the timing and me noticing it with no music on for once.
(Also, this is on an FR-S, so it's definitely not just a BRZ thing for those curious!)
eriktherod is offline   Reply With Quote
Old 06-11-2012, 07:12 AM   #48
ej
Drives: scion tc,frs
Does it sound kind of like cricket ??
ej is offline   Reply With Quote
Old 06-11-2012, 09:22 AM   #49
zygrene
zygrene's Avatar
Drives: 1991 Formula Red NSX
I freaked out just like you when I heard the clicking under my Audi A3 2.0T's hood (graduation gift, parents put a refundable $500 deposit on a BRZ but changed their minds when they saw one in person, I nearly cried) and posted on an Audi forum. Guy said it was just the DI system. I took the car to the dealer anyway and they reaffirmed that it was nothing to worry about.
You're probably already reassured at this point with all these replies from people stating it's the DI, but I thought I'd give another +1 for the hell of it.
zygrene is offline   Reply With Quote
Old 07-02-2012, 04:45 PM   #50
AbidingDude
Drives: 2013 Subaru BRZ Limited WRB
I have started noticing that cricket sound when the engine is idling. Any ideas?
Someone in a different thread said it might be the idler pulley making that high pitch cricket sound.
AbidingDude is offline   Reply With Quote
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 11:11 AM
Worried about Buying a Manual cmspooner BRZ First-Gen (2012+) — General Topics 100 06-06-2012 10:22 AM
Worried about the demographic that will buy the frs? RearDrive Scion FR-S / Toyota 86 GT86 General Forum 108 05-10-2012 07:18 PM
Things that I'm worried about... CSOCSO Scion FR-S / Toyota 86 GT86 General Forum 35 11-23-2011 01:37 AM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 04:31 PM
