Old 12-28-2015, 05:15 AM   #1
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Additional considerations when boosting
I found this article which I thought gave a nice insight into some of the considerations when looking to boost the FA20...
So, considering I am keen on the Edelbrock SC, and considering the long debates everyone has about how it will affect your car i.t.o. reliability etc, I thought it was worth sharing.
I am by no means the doyen of SC/TC, but there is definitely a ton of "opinion" on here that isn't always correct
http://www.revvolution.com/blog/2014...he-fa20-4u-gse
I like driving!
86 South Africa is offline   Reply With Quote
The Following 2 Users Say Thank You to 86 South Africa For This Useful Post:
Phantobe (12-28-2015), xkalelx (12-28-2015)
Old 12-28-2015, 06:26 AM   #2
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Thanks for sharing! That's a good write up on a post FI teardown. One thing to note, since that article has been out for a while, is that it HAS been determined that the rods are the weak point and (from what I keep reading) if you are are making more than 300-350 whp, you are on borrowed time with them.
Heres some pretty good evidence of that from Moto East and MAP performance. http://www.ft86club.com/forums/showthread.php?t=98229
xkalelx is offline   Reply With Quote
The Following 2 Users Say Thank You to xkalelx For This Useful Post:
86 South Africa (12-28-2015), Andew727 (12-28-2015)
Old 12-28-2015, 07:30 AM   #3
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Figure if you are even 325whp, that's nearly double the whp to factory. For anyone to expect more out of a factory engine is insane. Also noted there is alot of small things that need to have taken care of, like...
Clamping all the vacuum lines.
Installing a check valve on evap line to prevent boosting your gas tank.
Cooling, engines hate heat.
Don't apple boost to crank case by using the wrong catch cans setup.
List go's on.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 12-28-2015, 11:55 AM   #4
Andew727
Drives: Scion FR-S
List go's on.
which vacuum lines other than the one under the intake manifold?
and what catch cans work? or whats needed to make a basic catch can work? petcock?
Andew727 is offline   Reply With Quote
Old 12-28-2015, 03:18 PM   #5
86 South Africa
Ooh. Nasty pic!
I've read similar stuff re the rods.
I like driving!
Old 12-28-2015, 03:43 PM   #6
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Nice read. Really enjoyed learning more about our engines.
Instagram: trevor.parque
86 South Africa (12-29-2015)
Old 12-28-2015, 03:55 PM   #7
totopo
Drives: 370z
Pretty sure it's a teardown of a stock (NA) motor with 18k miles in preparation for future FI, not a post-FI teardown.
totopo is offline   Reply With Quote
Old 12-28-2015, 04:21 PM   #8
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
From the first post, it is clear it was FI via Sprintex 335 blower:
So lets kick this off. This car Started out in 2014 as a daily driver First thing i did to the car Was a set of
KW V3 coilovers then wheels and tires and at this point as most of you know, the need for more power comes into play.
I started off with a Sprintex 210 Blower I needed more power went to a 335 the car with the 335 Made around 276 Wheel
Horsepower on a mustang dyno. While driving along at above 120 MPH the car developed a tick.
Turns out that "tick" was actually piston slap. So off to moto east it went to begin forming a plan.
(pictured below are the pistons)
Later, we find that is running 19 PSI:
We've made some mention about what our thoughts are here in other threads, but generally we don't recommend running for a prolonged period of time on pump gas at high loads and boost > 14 psi. That goes for any setup.
Inlet temps of 160 F are not that unusual on a high boost SC setup. When you do that for a prolonged period of time then the chance of knock goes up substantially, and there's nothing you can really do from a tuning standpoint to fix that. Just lower compression and better cooling or e85. At less than 12 psi it is not a big deal, but with the 19 psi the 335 was doing, that was a lot to ask from the stock motor and pump gas.
Sleepless is offline   Reply With Quote
Old 12-28-2015, 04:58 PM   #9
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
19psi from a supercharger is a lot of low-end torque. No wonder the rods were bent. I'm honestly surprised they weren't more deformed than the picture shows.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 12-28-2015, 05:58 PM   #10
totopo
Drives: 370z
I meant the original revvolution/scr teardown. responding to the "That's a good write up on a post FI teardown. " Not talking about the other thread and rod.
Old 12-28-2015, 06:54 PM   #11
xkalelx
xkalelx's Avatar
Good catch @totopo I hadnt had my coffee yet when I posted that, thanks for the correction.
Considerations for a new car addition! frX50z Other Vehicles & General Automotive Discussions 19 11-03-2015 11:17 PM
Boosting Auto 13' Frs SPAGNOLA Scion FR-S / Toyota 86 GT86 General Forum 9 04-06-2015 11:19 AM
Boosting my FR-S Team86 Forced Induction 48 11-10-2014 06:24 PM
General boosting question Pneub Forced Induction 8 10-30-2013 02:36 AM
