Old 11-28-2015, 10:37 PM   #1
-Phil
Drives: Rb25 neo brz
Moto east and Map Performance turbo brz build
At the start of this thread i'd like to thank Mister Michael Mann @ Moto-East and Ian and Nate at Map performance
So lets kick this off. This car Started out in 2014 as a daily driver First thing i did to the car Was a set of
KW V3 coilovers then wheels and tires and at this point as most of you know, the need for more power comes into play.
I started off with a Sprintex 210 Blower I needed more power went to a 335 the car with the 335 Made around 276 Wheel
Horsepower on a mustang dyno. While driving along at above 120 MPH the car developed a tick.
Turns out that "tick" was actually piston slap. So off to moto east it went to begin forming a plan.
(pictured below are the pistons)
We went with the obvious idea of building the motor and pairing that with the best modification you can do to your
frs/brz Which is of course the Map Performance turbocharger kit with a garret Gtx3076R all this came ready to run out of
the box so the turbo components were set aside and the teardown began
Heres an Exert From Michael Mann about the state of the motor "So we tore down a motor today from a pretty nasty
engine failure. Amazingly it did not blow a hole in the block, but the carnage is quite impressive. What stands
out here is that there are 0 signs of knock, no pits in the piston tops or valves, no ring land damage at all
except where the piston gouged into the bore. What we're thinking is either a severe overheat due to sustained
high speed/high boost operation without an oil cooler on pump gas, or possibly too tight of ring gaps from the
factory leading to this failure when combined with the high temperature condition. ALL pistons showed scoring.
All rods are bent"
to remedy this the block was honed out .5 and the following parts were used in the motor
Cp pistons 11:1
carrillo rods
OEM bearings
oem valves
GSC springs
Oem rockers
all new oem seals
The car is currently making 527 due to running out of injector at the top. Stick around for an update on the 600 mark and where we take it from there!
[ame="https://www.youtube.com/watch?v=1ux7a9F0EK4"]https://www.youtube.com/watch?v=1ux7a9F0EK4[/ame]
***updating slowly, apologies for that***
Upate pictures as the car currently sits 12/6/15
08/02/16
Mods list,
--Engine
Cp pistons
Carrillo Rods
GSC springs
Arp Studs
Cometic Gaskets
Supertech Valves
Map Performance turbo kit
Gtx3076x turbo
Tial Waste gate 38
Tial Bov
Shmuck Built catch can
Battery Relocate
Ecutek Tuning system
Accusump oiling system
Exterior
Rocket Bunny v1
Ccw d240 18x12 Rear 18x10 front
Toyo R888 295 rear 265 front
Street faction Chassis mount
gtc500 Wing
Singular end-plates
velox rear diffuser
Velox version Race front splitter
Suspension
Tarmac 2 coilovers
Swift springs 13k rear/ 11k front
Velox LCA
Velox Toe arm
Cusco trailing arms
Whiteline 18MM rear sway-bar
Whiteline 22mm front sway bar
Whiteline Endlinks
Arp wheel studs
Interior
Custom 6 point cage
Sparco Ergo Seats
Sparco 6 point harness
Aem Wideband fail-safe
Aem Oil pressure gauge
Racecapture track datalogger
brakes
Velox brake cooling ducts
Stoptech 328mm st40 brakes front
stoptech pads and rotors in the rear.
-Phil is offline
The Following 17 Users Say Thank You to -Phil For This Useful Post:
Calum (11-29-2015), clayrush (11-29-2015), Freeman (11-29-2015), GhostOp86 (11-30-2015), illmatic (11-29-2015), Kris86 (11-01-2016), limitedblkwrx (12-07-2015), LOLS2K (11-29-2015), Lonewolf (12-01-2015), MAPerformance (12-02-2015), mrk1 (11-28-2015), R2RO (02-20-2016), raven1231 (12-03-2015), Sportsguy83 (11-30-2015), TheMedakaBox (03-13-2016), whataboutbob (11-30-2015), xkalelx (11-29-2015)
Old 11-29-2015, 01:48 AM   #2
FirestormFRS
Nice work fellas.
FirestormFRS is offline
The Following User Says Thank You to FirestormFRS For This Useful Post:
Old 11-29-2015, 08:57 PM   #3
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Um, Wow... Those rods just made to 1000% paranoid now.
276WHP Mustang is around 300WHP Dynojet. I wonder how many people her have bent rods that don't know it and their car is pushing 400+WHP? The factory rods really look like a ticking time bomb.
Time to stop driving the car until I save the rest of the cash for the build. Thank you Moto East for this write up. HUGE +1
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline
Old 11-30-2015, 05:19 PM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Factory rods being a time bomb is not news
SkAsphalt is offline
The Following 2 Users Say Thank You to SkAsphalt For This Useful Post:
Freeman (11-30-2015), raven1231 (12-03-2015)
Old 11-30-2015, 05:54 PM   #5
FRS Justin
Drives: 2013 Asphalt FRS
What turbo you running??? How many PSI are you going to go
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline
Old 12-02-2015, 12:52 PM   #6
MAPerformance
Drives: Asphalt FRS
They are running a GTX3076R.
Looks great so far Phil!
MAPerformance is offline
The Following 2 Users Say Thank You to MAPerformance For This Useful Post:
FRS Justin (12-02-2015), raven1231 (12-03-2015)
Old 12-02-2015, 01:31 PM   #7
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Do you think the bent rods here are a result of so much low end torque from the 335 blower?
I know you only had 276whp up top, but my guess is you were pushing at least that much in torque fairly low in the rev range as well.
Additionally, would you venture to say that a centrifugal setup that makes that same hp up top would be safer for the engine, as lower RPM torque is less?
xsnapshot is offline
Old 12-02-2015, 03:59 PM   #8
-Phil
Generally with these things you can never be sure but we were thinking this had more to due with the extremely high intake temperatures that occurred at sustained load. I would say that keeping the power away from the bottom will help
-Phil is offline
The Following User Says Thank You to -Phil For This Useful Post:
SkAsphalt (12-04-2015)
Old 12-02-2015, 06:30 PM   #9
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
What size housing on the hotside of the turbo?
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline
Old 12-02-2015, 08:02 PM   #10
-Phil
Housing is an .63
-Phil is offline
Old 12-02-2015, 10:52 PM   #11
Jayvelliott
Drives: Subaru BRZ Limited
Moto,
Why does low end torque promote the inevitable reaction of a bent rod?
Is this just a native problem Subaru/Boxster engines succumb to or is this a global/standard rule when going the FI route?
Being that the S/C is always applying load to the engine, is this problem more common in S/C kits rather then Turbo kits?
Thanks!
She asked me what I wished for on my wishlist...
Have you ever asked your bitch for other bitches?
Jayvelliott is offline
Old 12-02-2015, 10:56 PM   #12
Jayvelliott
Moto,
I'm unsure if you have any knowledge or experiences with the two but how do you think this Kit compares to the JDL and FBM kit?
Pro's/Con's so far about this kit? Did you have to modify the crash beam for this install?
Side note: I do like how the IC pipe is positioned over the cool side of the turbo..looks very nice.
Old 12-03-2015, 10:45 AM   #13
-Phil
Originally Posted by Jayvelliott View Post
Moto,
I'll Call on @moto-mike to answer your questions above but as for this kit really came as an actual complete kit. It actually comes with a pre modified crash beam ready to install. As far as the other kits though there's a reason we chose to do this kit, its routed nicely placed in a way that manages heat well and looks attractive not to mention the quality of material used was outstanding
-Phil is offline
Old 12-03-2015, 10:51 AM   #14
MAPerformance
Drives: Asphalt FRS
Yes, two small notches need to be cut out of the rear of the crash beam to clear the intercooler piping. We do have an optional tubular crash beam bar that is a direct bolt on if you wish not to cut into your factory one.
Optional crash beam bar:
Moto,
Moto-East tuning post_break User/Vendor/Sponsor Reviews, Feedback, Comments 10 10-25-2016 04:57 PM
Caravan to Moto-East from NYC LI Liquid6 NY / NJ / CT / PA 10 05-04-2015 09:38 PM
Moto East Bluetail User/Vendor/Sponsor Reviews, Feedback, Comments 1 01-25-2015 09:12 PM
Moto-East (Moto Mike) Review Thread ecko04 User/Vendor/Sponsor Reviews, Feedback, Comments 4 05-22-2014 07:57 PM
GReddy Turbo Kit Now Available at Moto-East! Xero-Limit Forced Induction 1 12-27-2013 02:20 PM
