Old 12-25-2015, 09:40 PM   #1
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Recommended Alignment Settings?
I'm going to be installing a set of Tein Flex Z's and SPC LCA's tomorrow, looking to lower the car 1"-1.5". Is there a range of camber/caster/toe settings that is generally recommended for a DD with occasional spirited driving? Or is the stock alignment fine? I would like to have an idea of the settings I need before I set the appointment for the alignment.
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 12-25-2015, 10:42 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Front: -1.5 degrees / 0 toe (a little out if you want)
Rear: -1 to -1.5 degrees / 0 toe (a little in if you want)
tyler_win_photo is offline   Reply With Quote
Old 12-27-2015, 04:48 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You give this answer like there is only one setting to be had. What does "a little in/out if you want" actually mean? You haven't explained what having zero toe at the rear or toe out at the front does to the steering.
@BFIFE22
Have a read of this thread:
http://www.ft86club.com/forums/showt...nment+settings
Alignment, like a lot of other things, is a compromise. I'm on 6k/6k springs, the same as Tein Flex Z for the triplets, and I'm running -3.2/-2.7 camber. It depends on what you're trying to achieve. I am not suggesting you go with -3.2/-2.7 camber; I'm just saying it depends.
Having 0 toe at the rear makes the rear less stable. That is, more prone to wander but it also makes the car easier to induce over-steer. I have settled on 0.3mm toe-in/side but it took 2 alignments to arrive at this figure.
Old 12-27-2015, 10:22 AM   #4
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
@BFIFE22
That's a pretty aggressive alignment. Are you running that on street? What kind of camber wear are you getting?
smg1138 is offline   Reply With Quote
Old 12-27-2015, 10:54 AM   #5
Cole
Not a troll
Cole's Avatar
Probably very minimal
Cole is offline   Reply With Quote
Old 12-27-2015, 04:27 PM   #6
Captain Snooze
Drives: Red Herring
Aggressive? My alignment doesn't try to pick fights lol. As for camber wear I get bugger all but as I said earlier because compromise. My alignment is biased for track use especially now I've gone back to softer (6k/6k) springs.
The OP mentions "occasional spirited driving" so there probably isn't too much need to take tires into account.
As I have tried to emphasize there is no one right answer.
Old 12-27-2015, 04:57 PM   #7
tyler_win_photo
@BFIFE22
OP was asking for recommendations based on his driving style, so I gave him a recommendation.
A little toe in in the front makes the car more stable in a straight line, toe out will make the car slightly less stable in a straight line but will have quicker turn in.
Alignment settings for Auto club speedway ddeflyer Tracking / Autocross / HPDE / Drifting 12 07-08-2015 08:10 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Recommended Toe Alignment Settings brillo Tracking / Autocross / HPDE / Drifting 18 02-05-2014 11:36 AM
recommended alignment shops in Az (tempe/chandler/mesa preferred) Juggles Southwest 1 11-19-2013 03:33 PM
RCE yellow springs. Expected alignment settings after install. diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-24-2013 02:48 PM
