#113 | |
Drives: Firestorm 2013 FR-S
The diff is a fairly complex assembly of gears. If something isn't adjusted right when it is assembled the gears make noise and will wear prematurely.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
#114 |
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Ive had this problem and im about to start going through the process of getting it fixed at my Subaru dealership.
#115 |
Drives: '13 BRZ - SWP
Has anyone gotten a fix from the dealership yet?
#116 |
Like last post asked has anyone done this and or have details on what was done because i a about to start the process of getting this fixed but i am wanting to do my new final drive but this is holding me up at the moment.
#117 |
Drives: 2015 AOZORA EDITION
Found out that it was my tires, cant believe how noisy hankook rs3 are
Sent from my SM-N920W8 using Tapatalk |
#118 |
In the process right now with the Subaru dealership and Subaru getting this issue resolved on my car.
#119 |
#120 |
The Fail Boat
Drives: CWP S.B.
Stock sound tube is annoying @ that speed. Clog it up!
| The Following User Says Thank You to chaoskaze For This Useful Post: | Tcoat (12-23-2015) |
#121 |
Update:
Had my car at Subaru and they took it out to try and replicate the noise but were unable to but noted that i had a loud aftermarket exhaust ofcourse. I had sent them a sound recording before hand that you could clearly hear the noise between 68 to 72 MPH. My plan is after talking with them is to take someone out hopefully this Saturday and have them hear the noise.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
#122 |
Drives: 2016 Halo FR-S
I have this issue at 68-71mph on my new 2016 as well, since day 1. My solution to the problem is to not linger at those speeds. Secondary solution is to turn up the volume on my stereo. It's worked well for the past 5000 miles. I wouldn't let the dealership anywhere near my differential unless I had no other option. End up with some scrub tech working on it and you'll be in for worse trouble down the road instead of a little noise.
#123 | |
#124 |
If you know the person working on your car that makes a huge difference, especially at a dealership.
#125 |
Scheduled this Saturday morning first thing to drive a mechanic in the car and point out the noise to them so see how that goes.
#126 |
Drives: WRB 2013 Subaru BRZ Limited
If you have stock exhaust, and add Whiteline bushing inserts to the trans, differential and subframe, this noise will increase quite noticeably as a high pitch whistle right around 69-73mph for me. I never noticed it before the bushing inserts. No whistle at 35mph, but slight vibration from the bushings. Definitely coming from differential though. speed dependent and not throttle input. Just my personal experience.
| Intake resonance pipe? | tranzformer | Engine, Exhaust, Transmission | 20 | 12-05-2011 05:09 AM |
