Old 08-29-2015, 08:07 PM   #113
pantdino
Drives: Firestorm 2013 FR-S
Originally Posted by 86Tony View Post
Why does the diff produce this noise?
Sent from my SM-N910W8 using Tapatalk
The diff is a fairly complex assembly of gears. If something isn't adjusted right when it is assembled the gears make noise and will wear prematurely.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 09-04-2015, 11:22 AM   #114
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Ive had this problem and im about to start going through the process of getting it fixed at my Subaru dealership.
rjgough95 is offline   Reply With Quote
Old 09-18-2015, 09:33 AM   #115
Monoman
Drives: '13 BRZ - SWP
Has anyone gotten a fix from the dealership yet?
Monoman is offline   Reply With Quote
Old 10-12-2015, 12:39 PM   #116
rjgough95
rjgough95's Avatar
Like last post asked has anyone done this and or have details on what was done because i a about to start the process of getting this fixed but i am wanting to do my new final drive but this is holding me up at the moment.
Old 11-07-2015, 09:35 AM   #117
86Tony
Drives: 2015 AOZORA EDITION
Found out that it was my tires, cant believe how noisy hankook rs3 are
Sent from my SM-N920W8 using Tapatalk
86Tony is offline   Reply With Quote
Old 12-22-2015, 02:34 PM   #118
rjgough95
rjgough95's Avatar
In the process right now with the Subaru dealership and Subaru getting this issue resolved on my car.
Old 12-22-2015, 10:13 PM   #119
Monoman
Let us all know what they find .. if anything.
Old 12-23-2015, 08:28 AM   #120
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Stock sound tube is annoying @ that speed. Clog it up!
The Following User Says Thank You to chaoskaze For This Useful Post:
Tcoat (12-23-2015)
Old 02-17-2016, 08:51 AM   #121
rjgough95
rjgough95's Avatar
Update:
Had my car at Subaru and they took it out to try and replicate the noise but were unable to but noted that i had a loud aftermarket exhaust ofcourse. I had sent them a sound recording before hand that you could clearly hear the noise between 68 to 72 MPH. My plan is after talking with them is to take someone out hopefully this Saturday and have them hear the noise.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
Old 02-17-2016, 05:09 PM   #122
Astral Abyss
Drives: 2016 Halo FR-S
I have this issue at 68-71mph on my new 2016 as well, since day 1. My solution to the problem is to not linger at those speeds. Secondary solution is to turn up the volume on my stereo. It's worked well for the past 5000 miles. I wouldn't let the dealership anywhere near my differential unless I had no other option. End up with some scrub tech working on it and you'll be in for worse trouble down the road instead of a little noise.
Astral Abyss is offline   Reply With Quote
Old 02-18-2016, 09:26 AM   #123
rjgough95
rjgough95's Avatar
Yes any other time i would not trust a tech to work on something like that but being that i know the one at the dealership and he also told me that they would not be working on the diff itself they would change it out for an entirely different one.
Old 02-18-2016, 10:40 AM   #124
Astral Abyss
If you know the person working on your car that makes a huge difference, especially at a dealership.
Old 03-10-2016, 09:57 AM   #125
rjgough95
rjgough95's Avatar
Scheduled this Saturday morning first thing to drive a mechanic in the car and point out the noise to them so see how that goes.
Old 03-10-2016, 02:51 PM   #126
bjreynolds202
Drives: WRB 2013 Subaru BRZ Limited
If you have stock exhaust, and add Whiteline bushing inserts to the trans, differential and subframe, this noise will increase quite noticeably as a high pitch whistle right around 69-73mph for me. I never noticed it before the bushing inserts. No whistle at 35mph, but slight vibration from the bushings. Definitely coming from differential though. speed dependent and not throttle input. Just my personal experience.
bjreynolds202 is offline   Reply With Quote
Intake resonance pipe? tranzformer Engine, Exhaust, Transmission 20 12-05-2011 05:09 AM
