Old 12-05-2015, 03:43 PM   #113
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by piaoyi View Post
Does anyone know if this is an interference type engine and can make contact with the valves?
It's not
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-13-2015, 10:41 PM   #114
thambu19
Drives: Scion FRS
Ignition timing at low speed WOT
Hey guys I was just comparing the OTS intake cam timing map and the changes made to it and saw that at low speeds the intake cam is fully phased (more overlap) but the ignition timing has not been changed much.
Are you guys feeling a better torque at the low speeds 2K and below with the OTS maps compared to stock? Fill me in please.
I have to think Toyota made cams go to lock pin at 800rpm to avoid any chance of pre-ignition by lowering the effective compression ratio.
thambu19 is offline   Reply With Quote
Old 12-13-2015, 11:51 PM   #115
shr133
shr133's Avatar
Drives: 2013 FRS
Well here is my seat of the pants cam table right now.... I'm to the point I need a dyno or acceleration times to fine tune...
Bottom line is what ever makes it faster is the best set up..........
I abandoned most stock settings....
So far seams the best set up is to run the cams with the same map, but I need to fine tune...
I'm NA, with a short ram intake, filter, no pvc and TRD cat back, auto...
I feel most of the exhaust timing was set up for emissions, runs much better now...
Next step is to do some 2nd gear roll ons and data mapping this spring...
But I'm 100 % happy with the low end just need to verify mid and top end..
But runs really good.... Sounded way cooler with more intake timing but I think it runs better like this...
shr133 is offline   Reply With Quote
Old 12-14-2015, 11:49 AM   #116
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I've done quite a bit of AVCS tweaking myself. I'll give your tables a try today.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 12-14-2015, 10:38 PM   #117
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Did you add KCA to base timing? Because comparing Base Timing itself to Stock will lead you down the garden path.
You can get some files with flat KCA from one of my threads so you can compare total timing all you want. You'll find the openflash tunes have MUCH less timing at high rpm / low load.
Or Kodename probably has a spreadsheet for it along with everything else.
Old 12-14-2015, 10:56 PM   #118
shr133
shr133's Avatar
Drives: 2013 FRS
I'm happy with it so far has way more low end, I can chug in 6th gear now...
and for daily driving almost no reason to manual shift.... Don't know if that good or bad....
Still have to work out full throttle but it seams really close...
Be interesting to get some feedback to see what other people think, or some ideas to try...
Old 12-14-2015, 11:08 PM   #119
thambu19
Drives: Scion FRS
So KCA has been dropped as well at the low speed WOT.
I think moving the cams more advanced definitely improves VE but comes with higher overlap. At super low speeds when intake is opened during the exh stroke its going to increase residuals. So id have expected a different timing. Appears like the higher effective comp ratio with advanced intake prevents a more advanced spark for some reason.
If anyone has a dyno compare of Stock Vs OTS Stg1 93 Oct that might be helpful
Old 12-17-2015, 12:51 PM   #120
KoolBRZ
KoolBRZ's Avatar
What are you using for your "Base" tables?
The mid and top end are a bit flat, so I tweaked them a bit. Now I have a Phantom SC and a long-tube 3" header, so I've got more scavenging going on. Here are my latest take on your AVCS table, and my base Intake table.
As far as dyno tuning @shr133, that's only good for top-end, not for daily driving. If you use an OFT, watch the Engine Load to determine performance. The lower the Load, the better the performance, and mileage too.
Last edited by KoolBRZ; 12-18-2015 at 12:25 PM. Reason: I posted the wrong map before. Here is the better one.
Old 12-18-2015, 02:01 AM   #121
shr133
shr133's Avatar
Drives: 2013 FRS
Looks good, I like your tweaks, I'm still tuning, but may be done till spring....
I'm N/A and stock header.
I'm running the the same map on my base and exhaust....
I think I'm going to back down the exhaust map from 30 to 25 in the mid range...
and bump the intake map up in the mid range..
I think we can run more intake than exhaust timing but haven't had the time to verify it yet...
I want to use this map as my base and start getting some solid acceleration times... If I get the time...
This is my do it all map until I up grade to full race rom...
It uses a little more gas than stock but is running too good...
I want to make a MPG map and a more aggressive map...
Sweet, nice to bounce ideas off someone.....
Old 12-18-2015, 02:09 AM   #122
shr133
shr133's Avatar
Drives: 2013 FRS
I do remember in tuning It pulled harder with more cam timing but felt more peaky and was smoother over all with a little less...
but I'm not done, are we ever done????
Old 12-18-2015, 12:01 PM   #123
KoolBRZ
KoolBRZ's Avatar
Glad to hear you're running the same map as base
I'm trying out a more aggressive map, but with a less aggressive base map. I used your map up to 1.0 load, with a few tweaks to smooth it.
Old 12-19-2015, 12:12 PM   #124
KoolBRZ
KoolBRZ's Avatar
The Base maps are critical to AVCS tuning
I tried out a tune with modified base maps yesterday. It felt like too little, too much. Not much under 2800 RPM, then it really screamed. AFR's were all over the place. I switched back to a known good tune right away. I've found it's always good to keep at least one known-good tune in my OFT, then try out with the other four tunes. Today I'm trying out slightly de-tuned Base tables. I reduced the highest numbers and smoothed out the dips, since I am FI I don't need compensation for the dips. If it works better I will post it. I have determined, however, that the Base tables are active, no matter what temp the engine is at.
Old 12-19-2015, 01:37 PM   #125
Kodename47
Kodename47's Avatar
Drives: UK GT86
Please do explain then how the base/normal/safe all interact....
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-19-2015, 02:24 PM   #126
KoolBRZ
KoolBRZ's Avatar
If I knew that...
I'd like to give a shout out to @Td-d to answer that question. There are also several other experts who could answer that, but he is the only one who comes to mind. There should be a sticky, with a definition of how the tables affect the tune, and under what circumstances. I would also like to know in what order to make changes. Which table to alter first, start from the top of each table and work down as each row is tuned for optimum, or should it be each column?
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-10-2016 11:25 PM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 03:01 PM
Stock Rom: Timing + Learn Value sw20kosh Software Tuning 7 12-11-2013 07:09 PM
E85, Boost and Ignition Timing jamesm Software Tuning 23 12-11-2013 02:19 PM
Timing belt shredded..?! drei CANADA 5 12-06-2013 05:54 PM
