CANADA Canada
Old 12-06-2013, 03:10 PM   #1
drei
drei's Avatar
Drives: 2013 Scion FR-S Asphalt
Timing belt shredded..?!
So I was driving yesterday to the dentist and all of a sudden started hearing a sound from the car, at first i thought it was clicking, but sounded more like a rubber slapping sound which increased with the revs and remained happening at idle.
Stopped the car, look int he engine, couldn't see anything odd.
Called dealership they told me to bring the car in. Halfway to the dealership the slapping stopped and battery light went on.
At the dealership they showed me the timing belt which was shredded. I asked why, they said probably because it skipped....
How does that happen on an engine that's under 26k?
At least warranty covers it
drei is offline   Reply With Quote
Old 12-06-2013, 03:19 PM   #2
Dipstik-sportech
Dipstik-sportech's Avatar
These cars use timing chains not belts. Either you misheard the dealer and he said accessory drive belt or he's an idiot. The accessory belt drives everything at the front of the engine including the alt, which would explain your batt light coming on
Old 12-06-2013, 03:30 PM   #3
wparsons
wparsons's Avatar
^^ This, it wouldn't be the timing belt even if it was a belt on these engines. If a timing belt snaps your engine wouldn't keep running for even a second.
flickr
Old 12-06-2013, 03:34 PM   #4
drei
drei's Avatar
Now this explains half of my confusions..
You must be right. I swear he said timing belt which led me to be very confused, but I must have misheard. It must have been the accessory belt.
Thanks.
What could be the reason for the shredding?
Old 12-06-2013, 04:10 PM   #5
abitolder
Drives: 2013 FRS Argento MT
seizing pulley on tensioner? Belt too loose?
abitolder is offline   Reply With Quote
Old 12-06-2013, 05:54 PM   #6
Dipstik-sportech
Foreign body falling between the belt and pulley, normal wear although at the mileage u stated the belt should be fine still. Odd
OAKOS/DVR Service Specials! Clutch Install $399! Timing Belt $199! St. Heights, MI OAKOS Automotive Great Lakes 78 05-14-2015 12:10 PM
E85, Boost and Ignition Timing jamesm Software Tuning 23 12-11-2013 02:19 PM
ECU pulls timing at high oil temps? brillo Engine, Exhaust, Transmission 24 03-31-2013 09:10 PM
Valve Timing/Computer miss paula Issues | Warranty | Recalls / TSB 3 09-20-2012 03:27 PM
AZP Sept Special: $100 OFF Timing Belt Service AZP Installs NY / NJ / CT / PA 0 08-31-2012 05:58 PM
