Old 05-13-2014, 04:59 PM   #15
PMPB
Drives: BRZ Sport-tech
I have a gravel driveway that has a small grade and I used the scissor trunk jack to swap my summer on in about 45minutes, no problem.
The only weird thing is that the jack doesn't really engage the pinch with the groove (the groove in the jack is too deep) so it's lifted on the frame adjacent to the pinch, and I got a small transfer of the factory underbody spray onto my jack.
PMPB is offline   Reply With Quote
Old 05-13-2014, 05:21 PM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
OP doesn't respond to his own help thread...
Old 05-14-2014, 09:19 PM   #17
mafrs1
Drives: 13 frs
hey thanks guys been a bit busy .think I got my answer e-brake wasn't engaged. car was on flat cement floor and jack was in front of rear wheel. got the spare in the wheel wel that saved the rotor from hitting the floor.no damage. thanks for the great response.
mafrs1 is offline   Reply With Quote
The Following User Says Thank You to mafrs1 For This Useful Post:
wheelhaus (05-14-2014)
Old 05-14-2014, 09:57 PM   #18
wheelhaus
wheelhaus's Avatar
Glad it was an easy solution an no damage occurred.
Old 05-14-2014, 09:59 PM   #19
DarkSunrise
DarkSunrise's Avatar
I've used the factory jack a number of times without issue. Obviously use the e-brake and it helps to put the transmission in gear, just in case. I also chock the wheels.
That's by design. The parts of the frame that the factory jack touches are reinforced. If you lift a car using a jack that only engages the pinch weld, you risk potentially bending the pinch weld.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
PMPB (05-14-2014)
Old 05-14-2014, 10:39 PM   #20
DarkCard
Drives: Asphalt Scion Frs 6MT
Mine broke.
DarkCard is offline   Reply With Quote
Old 05-14-2014, 10:55 PM   #21
CoupedUpSubie
Drives: 2013 BRZ Limited
The jack is exactly the same one that came in my 95 impreza. They wear out really quick.
OP: Good rule of thumb with emergency jacks is to throw something on each side of a tire(preferably the one farthest away from the affected tire) in order to prevent rolling. I don't trust emergency jacks or brakes to actually hold a car still.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 12-11-2015, 03:07 PM   #22
Astroboy
Astroboy's Avatar
Drives: None
Anybody ever lift the car by the frame
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 12-16-2015, 11:43 AM   #23
deadwolfbones
Drives: 2013 Scion FR-S (Argento)
I've (probably stupidly) used mine to change the tires about 4x since I got the car. No issues except scraping knuckles on asphalt.
deadwolfbones is offline   Reply With Quote
Old 12-16-2015, 03:03 PM   #24
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I've swapped to winter tires, then to summer tires, then to winter tires, also changed my brake pads, and had at least one flat tire (which involved jacking twice since it was a rear tire.)
So basically I've jacked my car up like 20 times with this jack and haven't had any issues.
Stang70Fastback is offline   Reply With Quote
$10 Jack Buddies blalor DIY (Do-It-Yourself) Guides 24 10-20-2017 08:16 PM
Bad Emergency Jack? JDMenrique Issues | Warranty | Recalls / TSB 35 11-27-2015 08:55 PM
JACK's BRZ! Mr. Jack Member's Car Journals 10 07-05-2013 10:19 AM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 02:53 AM
Jack Spots? feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 06-11-2012 10:09 AM
