Drives: 2016 Scion FR-S
Double Clutch vs Synchro wear
Would double clutching effectively reduce wear and tear on synchro?
Sent from my Nexus 5X using Tapatalk |
#2 |
Yes. But chances are the times you mess up trying to double clutch, would probably be worse than shifting regularly.
Let me guess... it is your first manual transmission car? |
| The Following User Says Thank You to swarb For This Useful Post: | Concorazon (12-08-2015) |
#3 | |
#4 |
New tech?
#5 |
Drives: Subaru BRZ Limited
are you referring to synchros as new tech?
| The Following User Says Thank You to JoeC For This Useful Post: | Cole (12-09-2015) |
#6 |
I'm used to driving beat up trucks not an FRS so yea its a bit of a shock
#7 |
Drives: 2013 Firestorm FRS
just make sure you're not granny shifting, not double-clutching like you should
| The Following 15 Users Say Thank You to continuecrushing For This Useful Post: | Apoc (12-08-2015), El Guapo (12-09-2015), fika84 (12-08-2015), GhostRai (12-09-2015), Griever423 (12-10-2015), MisterSheep (12-09-2015), Muaddib (12-08-2015), pushrod (12-08-2015), soulreapersteve (12-08-2015), STV3 (12-09-2015), Tcoat (12-08-2015), tigermack (12-08-2015), Turdinator (12-10-2015), WhiteFRS69 (12-08-2015), WingZer0 (12-09-2015) |
#8 |
| The Following 4 Users Say Thank You to Concorazon For This Useful Post: | continuecrushing (12-08-2015), soulreapersteve (12-08-2015), Tcoat (12-08-2015), tigermack (12-08-2015) |
#9 | |
![]() I just wished that the new, MT drivers, would quit listening to their drunk uncles, about how to shift a MT on modern cars…… On modern transmissions, I would say that double clutching will not significantly reduce wear and tear on the synchronizers, not in your average car’s lifetime. Yes, if your vehicle was old and/or had 18 wheels, yes, double clutching would be beneficial. Simplify your life …. just shift the damn car....... ![]() humfrz |
| The Following 11 Users Say Thank You to humfrz For This Useful Post: | clayrush (12-08-2015), Concorazon (12-08-2015), Griever423 (12-10-2015), kch (12-09-2015), sgtcarrot (12-08-2015), soulreapersteve (12-08-2015), stevesnj (12-09-2015), Summerwolf (12-09-2015), Tcoat (12-08-2015), Toyarzee (12-09-2015), wireman957 (12-09-2015) |
#10 | |
![]() Sent from my Nexus 5X using Tapatalk |
#11 | |
| The Following 2 Users Say Thank You to D_Thissen For This Useful Post: | Cole (12-09-2015), Packofcrows (12-08-2015) |
#12 |
hey you, yeah you <3
Drives: 2014 37J FR-S
clutch less shifting ftw
#13 |
Contrary to popular opinion on here these cars are not fragile little flowers.
Drive it and don't worry about whether it will last 10 years or 10 years and 4 hours.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#14 |
Drives: '13 FRS - STX
Experiment, do whatever makes the car happy.
I double clutch many of my downshifts on the street now (didn't during the first ~2 years of ownership), under 3k rpm but not when I'm at the track blipping the throttle to 7k. Seems backwards innit? But every car is different. I've ground gears, forced the lever into place and put it in the wrong gear, but never done any damage. 43k miles and I think it operates better than it did on day 1. It's not a delicate flower as long as you're at least trying to operate properly. |
| The Following 4 Users Say Thank You to strat61caster For This Useful Post: |
| Clutch wear on BRZ | kingstonalex | BRZ First-Gen (2012+) — General Topics | 15 | 09-04-2015 03:42 PM |
| Possible clutch wear? | Romanov | Engine, Exhaust, Transmission | 6 | 06-11-2015 09:12 PM |
| Clutch wear and pedal adjustment | mike the snake | Engine, Exhaust, Transmission | 4 | 10-29-2014 03:30 AM |
| Clutch wear? | Pakjk89 | Engine, Exhaust, Transmission | 102 | 04-12-2012 07:21 PM |
| Will FT-86 have Synchro Rev Match? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 05-27-2010 11:05 AM |
