Old 12-06-2015, 06:51 PM   #1
Benschneider06
Benschneider06's Avatar
Drives: Satin White Pearl Subaru BRZ
Lightbulb Tire Width & Fun Factor Discussion
The reasons our slow cars are such entertaining cars is because they're so much fun to drive on the streets. They get sideways at very low speeds with their skinny tires and have good balance.
Chris Harris has a YouTube video out called "The Mercedes C63 AMG Experiment" where he drives the C63 AMG on 4 spare tires. Sliding around everywhere. In this clip he says:
"Modern sports cars are now so obsessed with lap times and circuit performance that at normal road speeds they're most boring because they never come close to moving around and making the driver work" -Chris Harris
He basically has twice as much fun in the car with skinnier tires.
You guys get what I'm saying.
How wide do you think our tires can get before you have so much grip you lose that fun factor?
I was thinking about getting some 18x8.5 wheels next year with some sticky tires.. but every time I slide around a corner on my stock wheels, I think twice about it with a huge smile on my face.
What do you guys think?
Benschneider06 is offline   Reply With Quote
Old 12-06-2015, 07:06 PM   #2
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
Why 18"? looks? 17" can keep the weight down.
ottoyu34 is offline   Reply With Quote
Old 12-06-2015, 07:11 PM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Going from stock to 17x9 with 245/40 tires was one of the best mods I've done. I prefer grip over drift.
Originally Posted by humfrz
I'm old and lazy
The Following 4 Users Say Thank You to Clipdat For This Useful Post:
BigFatFlip (12-07-2015), Leonardo (12-07-2015), Summerwolf (12-07-2015), Teseo (12-17-2015)
Old 12-06-2015, 07:38 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
+1 to OP. For all those NOT regularly visiting track / auto-x-ing, for those staying NA and not installed forced induction, i see no reason going for insanely wide tires only for arguable looks improvement when one mostly daily drives. Of course if they still value that fun bit that was there in stock. Some might not care about handling changes at all, going just for looks. I certainly would miss it. In my eyes 215-225 tire width of better tire type then Primacies is maximum i'd ever go for mostly daily driven car. Will also help keeping wheel+tire weight down.
Ultramaroon (12-12-2015)
Old 12-06-2015, 07:48 PM   #5
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I'm running 225/50s on 16x7s. Best wheel and tire change I think I've ever made on ANY car I've owned.
Old 12-06-2015, 07:57 PM   #6
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
"Fun" is subjective. I run 255/35/18 as my definition of fun is going around corners as fast as possible on the limit of mechanical grip.
If I were into getting slideways I'd be running the stock rubber.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 12-06-2015, 09:54 PM   #7
Benschneider06
I haven't found any 17" wheel setups that I really cared for looks wise.. Any suggestions?
Old 12-06-2015, 10:23 PM   #8
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
I'm running the same. 17x9 with 245 tires. I can EASILY make the car go sideways if the road is just a little damp. 190whp
I cant say the same for 18s, but it should be similar
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 12-06-2015, 10:45 PM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Depends on your definition of fun.
Old 12-07-2015, 05:49 AM   #10
MrDinkleman
Drives: 2016 Oceanic, "base" model
What offset and do you have any pics?
TIA
MrDinkleman is offline   Reply With Quote
Old 12-07-2015, 11:01 AM   #11
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
I'm in the same dilemma more or less.
Seeing that the stock wheel is 7" wide, and if you're running a 17" wheel most people seem to go with a 17x9. So maybe a 17x8 would be a good compromise between grip and fun. Probably depends a lot too if you run high performance summers or all seasons.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 12-07-2015, 11:21 AM   #12
sanbaifo
Apex Premeditator
Drives: ZC6-C5AE-C7Z51-E36
This. Compound plays are large role here.
sanbaifo is offline   Reply With Quote
Old 12-07-2015, 12:32 PM   #13
AlexWood
Drives:
I had this same dilemma. I had 18x9.5's with 235s and hated the feel and how dull it made the car. I now have 17x9's with a 225 which is better, but I still miss the stock tires, they were too much fun to slide around everywhere. The problem is, I want the look of a wider wheel/tire but I also want the feeling the primacy's gave.
AlexWood is offline   Reply With Quote
Old 12-07-2015, 12:50 PM   #14
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I went to a lighter OEM Subaru 17x7 BBS wheel with some 225/45 Bridgestone S-04's. Huge improvement with some swift springs and a bit of camber. I can still put it plenty sideways, or drive it around mountain roads and maintain grip. Perfectly happy.
JazzleSAURUS is offline   Reply With Quote
fun, slide, tire advice, tire size, tire width
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 12:31 AM
Tire Width? wootwoot Tracking / Autocross / HPDE / Drifting 84 03-06-2019 07:44 AM
Tire Width/Compound Vs. Horsepower VroomVroom86 Forced Induction 43 02-14-2014 10:36 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
