Old 11-27-2015, 12:53 AM   #15
steve99
Drives: FT86
Originally Posted by Fakk View Post
Was the sound as if something metal was loose and tinkled back and forth under more than idle load? I think mine makes the same noise on startup and any load. If so, I guess I found my problem.
Right now I have Grimmspeed header gaskets, this "Subaru OEM 2.5" gasket from speedfactory between headers and overpipe, and a thicker gasket the rest of the way back. I took it to an exhaust shop, and they said I don't have any leaks.
that does not sound like a leak.
sounds like your overpipe or some other part of exhaust is hitting on chassis or front sway bar, skid plate etc.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
DocWalt (11-27-2015), Fakk (11-28-2015)
Old 11-28-2015, 12:48 AM   #16
Fakk
Drives: 13 BRZ Limited 6MT CBS
Might have to get the car back on a lift and check it out. I swear I made sure nothing was touching the past 2-3 times the car was up.
Fakk is offline   Reply With Quote
Old 11-28-2015, 01:00 AM   #17
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Make sure the overpipe isn't touching the engine.
Old 11-28-2015, 01:06 AM   #18
steve99
Drives: FT86
+1 overpipe hitting chassiss or front sway bar mount under load is very common
sometimes you need to drill a new mounting hole on front pipe support bracket to lift front pipe to stop overpipe hitting.
Old 11-29-2015, 02:03 AM   #19
k.houan
k.houan's Avatar
Drives: BRZZZ
Originally Posted by Trust86 View Post
^^^This guy knows his shit!
grab a new gasket and throw some high temp rtv on both sides and be done with it forever. Did this to all my exhaust gaskets from downpipe back on my S15 when I was in Japan.
Did you just follow the instructions? (I believe it says to hand tighten after applying then let it set before torqued fully) Or did you apply on both sides of the gasket then stick it on and torque to spec?
Sent from my Nexus 6P using Tapatalk
k.houan is offline   Reply With Quote
Old 11-29-2015, 02:38 AM   #20
Trust86
Drives: 2016 Halo FRS
follow the instructions, if you don't let it cure, all the rtv will squeeze out when you torque it. I put rtv on both sides of the gasket. Did that plus put some more around the gasket/pipe after I installed the gaskets.
Trust86 is offline   Reply With Quote
Driver side valve cover gasket leak solidONE Issues | Warranty | Recalls / TSB 59 02-22-2021 01:52 AM
Head Gasket leak? Carlsson Issues | Warranty | Recalls / TSB 8 10-23-2015 01:49 AM
Exhaust Gasket: OEM or Aftermarket? Wilcats Engine, Exhaust, Transmission 3 05-21-2015 09:22 PM
Revworks UEL gasket for stock overpipe wbradley Engine, Exhaust, Transmission 12 02-26-2015 10:42 AM
60mm Exhaust gasket denkigrve Northern California 2 07-02-2013 09:53 PM
