Old 09-02-2014, 06:19 AM   #1
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Driver side valve cover gasket leak
I don't think I've seen this one posted, although it might simply be because people don't really work on their cars enough to really spot something like this.
Short story shorter, I was working under the engine with the skid plate off and discovered that my driver side valve cover gasket has oil seeping out. A small amount. The car only has 18K miles currently. Anyone else seen this?
Old 09-02-2014, 10:14 AM   #2
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Mine is on the timing chain cover meets the block and valve cover.
This is the driver side. It comes out that one spot, but blows back and covers pretty much everything behind it.
F1point4 is offline   Reply With Quote
Old 09-02-2014, 01:12 PM   #3
solidONE
solidONE's Avatar
@F1point4 What the mileage on you car and when did you discover the leak? Have you try to warranty it?
Old 09-02-2014, 01:30 PM   #4
ftc~brz
Done
Drives: WRB BRZ
ftc~brz is offline   Reply With Quote
Old 09-02-2014, 02:21 PM   #5
vgi
Drives: frs
Got the same leak, although not as big as ftc~brz.
There are threads on this, one or two, search.
It was around 13k when I noticed and right after I got boosted, so no warranty will run it as is for some time and the will just trade it in for something else (not subaru. across wrx/brz these engines seem too have issues).
vgi is offline   Reply With Quote
Old 09-02-2014, 05:00 PM   #6
solidONE
solidONE's Avatar
Bummer... I'm hoping solutions to the issues are just around the corner for the fa20.
I haven't heard too many di seal problems after the newer tunes came out. So that's a good thing. And we got folks working on the oil pressure issue as well. Just got to be patient.
Old 09-03-2014, 11:33 PM   #7
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Don't worry there is hope!!! the ND miata is coming.
Muaddib is offline   Reply With Quote
Old 10-16-2014, 03:59 PM   #8
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I just found a small leak at the back/bottom of my drivers side camshaft cover.
Taking it in to the dealership on Monday.
Old 10-16-2014, 04:07 PM   #9
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Subarus seem to have a long history of leaking valve covers. My 07 impreza had this issue. Replaced the gaskets when under warranty. When they went again I said F*ck it, and drove 15k plus miles before I traded my car in. That included a trip cross country too.
When I brought it in to a mechanic out here, who owned an 05 sti, he said it wasn't leaking that bad, and if it was his car he wouldn't get them replaced. Who would have thought, a mechanic actually saying no its not bad replace it later, normally they are out for your $$$s
GotBRZ1691 is offline   Reply With Quote
Old 10-16-2014, 04:12 PM   #10
GotBRZ1691
GotBRZ1691's Avatar
I believe the mechanic said engines that are all aluminum are more prone to this because the block heats and cools faster, and the gaskets cooling rates are different and they cannot keep up with the expansion or contraction.
Plus being horizontal, gravity has more of an effect.
Old 12-06-2014, 03:06 PM   #11
Astroboy
Astroboy's Avatar
Drives: None
Me to. I turbocharged mine tho .. is yours still leaking? If so, is it leaking drastically? How many miles?Any mods?
Astroboy is offline   Reply With Quote
Old 12-06-2014, 07:52 PM   #12
ATL BRZ
ATL BRZ's Avatar
It has actually perceivably stopped leaking. Maybe it's just really slow. 11k miles. Full bolt on n/a with Flex-fuel.
Old 12-06-2014, 08:07 PM   #13
Astroboy
Astroboy's Avatar
Drives: None
That's good to hear, congrats.
And you have not took it to the dealership yet correct? I also changed my oil to motul's x clean 5w30
Old 12-06-2014, 08:09 PM   #14
ATL BRZ
ATL BRZ's Avatar
I have taken it to the dealership for it once. They couldn't find the source of the leak and just cleaned it up and sent me in my way after telling me to keep an eye on it.
Oil Leak on driver side EINSTEIN562 Issues | Warranty | Recalls / TSB 3 08-09-2020 12:16 PM
Water Leak inside passenger side floorboard AtlasMick Issues | Warranty | Recalls / TSB 30 03-28-2019 04:43 PM
oil leak, drivers side, front of engine carbonBLUE Issues | Warranty | Recalls / TSB 41 10-02-2015 11:51 PM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 09:42 PM
