Old 10-04-2015, 08:10 AM   #1
Carlsson
Drives: Toyota GT86 Vortech Supercharged
Head Gasket leak?
Hey! I recently discovered a small puddle on my engine. I'm not a boxer expert so I'm not sure what the area is called. My friend says after a harder drive this can be normal, but I am not too sure.
Info: I'm running Vortech Supercharger.
Cooling liquid is 1cm under minimum.
Oil on dipstick looks normal, same with oil lid.
Car has 16000km / 9900 miles on it.
Anyone know what it is, what it might be and if I can continue driving?
Heading for a longer drive now to see if I get any more of it.
Pictures.
Same place, different angle.
Imgur Album link:
http://imgur.com/a/VT7tj
Carlsson is offline   Reply With Quote
Old 10-04-2015, 08:40 AM   #2
steve99
Its certainly not normal.
Looks like engine oil , coolant from engine is usually blue if stock or possibly green
Clean it all off with degreaser ect then you might be able to see where its coming from on the next short drive. Looks like its been leaking for a while.
hopefully its the supercharger oil and not a cracked block, their is a suspect looking jagged line in that third photo closeup that looks like a crack
Whats the greenish/blue dried off stuff that might have been coolant ??
does the air con still work ?? , does not look like air con oil though
Old 10-04-2015, 09:35 AM   #3
Carlsson
We can ignore the coolant part about my previous post. It's normal. I've wiped it off and gone for a 50 min drive. No more leakage from what I can see. It's not oil from the supercharger, it has an internal oil reservoir, and it's red.
The green stuff is stuff that they have from the factory to check for leaks, or something along those lines.
Air Condition still works.
Old 10-04-2015, 04:33 PM   #4
humfrz
Good pictures!
Yep, something is (was) leaking for sure.
I have no idea of what is causing the leak.
Sorry, I'm no help ......
humfrz
Old 10-19-2015, 06:44 PM   #5
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Did you ever figure out where the leak was coming from?
BirdTRD is offline   Reply With Quote
Old 10-22-2015, 02:28 AM   #6
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
THAT LEAK IS FROM YOUR TIMING COVER. I've had mine fixed once already and it's back again. It is a not-unusual problem but it is a HUGE fix... @Carlsson
Keenercarguy is offline   Reply With Quote
Old 10-22-2015, 11:42 AM   #7
bababooey
Drives: BRZ SWP Limited -6MT
is this the same thing that people replace the cam plate cover to keep from leaking?
Old 10-22-2015, 06:01 PM   #8
monst
Drives: SAS supercharged 4Runner
Has this issue been addressed in a recall or TSB?
monst is offline   Reply With Quote
Old 10-23-2015, 12:49 AM   #9
Keenercarguy
Mountain Runner
I'm not sure… the timing cover is on top of the crank case and I think it is attached or at least close to the cam cover, but it's especially odd because the oil from the timing cover (which all the subaru technicians at my dealer have seen on the majority of the new boxers) is seeping out of the seal, despite that the crank case isn't under any pressure. The mechanic that I chatted with, after the leak came back a second time barely a month after the first fix, said that all the techs there think that it's because the 0W-20 is so thin and it just works its way out… Again apparently this is not uncommon in the FA-20 and similar new boxers… Once it's fixed this time i'm going to consider changing to a thicker oil.
Driver side valve cover gasket leak solidONE Issues | Warranty | Recalls / TSB 59 02-22-2021 12:52 AM
Head gasket install Andreas83 Engine, Exhaust, Transmission 1 09-07-2016 09:09 PM
Blown head gasket?? sachu Issues | Warranty | Recalls / TSB 14 07-15-2016 01:08 PM
Blown head gasket?? texasbound972 Engine, Exhaust, Transmission 29 05-19-2015 11:09 AM
is my head gasket blown? BrianBlueBRZ Other Vehicles & General Automotive Discussions 4 07-22-2014 09:45 PM
