Old 11-23-2015, 08:36 PM   #15
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Originally Posted by Heist View Post
Shell A is OEM Style. So order the OEM Pin from Auto Harness House. It's surprising that you had an Aftermarket Pin that is supposed to only fit in Shell B crammed into the Shell A.'
So, yeah. You have Shell A. Order OEM Pin. Splice and run it to the reverse signal and you should be good to go. Don't forget to lift the latch before inserting. Mine went in pretty easily even though I bent the plastic a little.
Yeah xD! I ordered the OEM Style. I didn't even know there was a difference until you mentioned it! In my car I have shell A. I received in the rear camera kit a shell B.
I received aftermarket pin that's why it wasn't going in I guess.
Now waiting for my order, when I get it.. I'll have to poke something sharp inside the pin to open the latch or do I open the latch of the shell?
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 11-23-2015, 09:44 PM   #16
Heist
Heist's Avatar
Drives: 10 Series
Same exact thing happened to me. Got a Type B pin for my Type A shell...
Just open the latch shell, just use a small screwdriver. It only pops up a little bit, so don't force it. It should click slightly when you pop up both sides. Since you've already extracted the pin, there shouldn't be a need to poke something sharp for the release.
Heist is offline   Reply With Quote
The Following User Says Thank You to Heist For This Useful Post:
Mikeez (11-23-2015)
Old 11-23-2015, 11:56 PM   #17
Mikeez
Engineering Student
Okay , thank you. I will try it when I get it!
Help: Sidemarker wire harness connector It's Jay Electronics | Audio | NAV | Infotainment 0 06-27-2015 10:51 PM
ECM Pin Connector simpleisbest Software Tuning 19 01-18-2015 02:13 AM
What's this connector ? mashal Electronics | Audio | NAV | Infotainment 5 12-10-2013 01:13 AM
Help, what connector is this? Hayashi Cosmetic Modification (Interior/Exterior/Lighting) 0 02-26-2013 01:39 AM
VSS Connector AlexTheGreek Engine, Exhaust, Transmission 15 02-02-2013 12:12 PM
