Old 11-17-2015, 08:42 AM   #113
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Enkei RPF1 17x9 +45, 245/40r17 I believe.
BoxRZ_86 is offline   Reply With Quote
The Following 6 Users Say Thank You to BoxRZ_86 For This Useful Post:
alxtheoreo (11-17-2015), Breeeep (11-17-2015), Lonewolf (11-18-2015), Plxdjake89 (11-19-2015), sniffpetrol (02-18-2018), SStratos (09-28-2017)
Old 11-17-2015, 11:23 AM   #114
alxtheoreo
alxtheoreo's Avatar
How much does it poke out in the front & rear?
Sent from my SCH-I545 using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 11-17-2015, 12:29 PM   #115
BoxRZ_86
BoxRZ_86's Avatar
None, its sits pretty flush.
Old 11-19-2015, 11:51 AM   #116
BoxRZ_86
BoxRZ_86's Avatar
I took a photo this morning to show the poke/flush of my setup.
The Following 3 Users Say Thank You to BoxRZ_86 For This Useful Post:
alxtheoreo (11-19-2015), sniffpetrol (02-18-2018), SStratos (09-28-2017)
Old 11-19-2015, 11:59 AM   #117
alxtheoreo
alxtheoreo's Avatar
Attachment 125393
Attachment 125394
I love it. Thank you!
I'm considering this set up, or Mach V Awesome wheels for next spring (+42 offset).
Do you have any rubbing at full lock?
Old 11-19-2015, 12:02 PM   #118
BoxRZ_86
BoxRZ_86's Avatar
No rubbing at full lock. But the inner barrel of the wheel slightly touches the spring perch now and then. I don't hear it or feel it but when you take off the wheel you can see a slight mark on the wheel from it touching. I will probably use a 3mm spacer on the front soon.
The Following User Says Thank You to BoxRZ_86 For This Useful Post:
Old 11-19-2015, 12:28 PM   #119
Parks_
Drives: 2015 Steel Scion FR-S
XXR 530's 17x7 +35 on stock wheels. Not the best picture of stock height. I would take more but I am in the process or installing my Eibach Sportline kit.
Parks_ is offline   Reply With Quote
The Following User Says Thank You to Parks_ For This Useful Post:
JonAvalon (11-19-2015)
Old 11-19-2015, 01:43 PM   #120
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
funwheeldrive (02-28-2016)
Old 11-19-2015, 05:39 PM   #121
Here2rock
Drives: 86 GTS
Originally Posted by YamahaR86 View Post
Very nice, a bit different to others, I like it. What are the specs?
Here2rock is offline   Reply With Quote
Old 11-19-2015, 08:12 PM   #122
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Thanks. Not entirely different, they're knock off wheels but for my first aftermarket wheel I think they're fine.
17" +35. Tire is 225/45/17
Here2rock (11-19-2015)
Old 11-19-2015, 08:38 PM   #123
stevesnj
stevesnj's Avatar
They fit the car perfect IMHO @YamahaR86
My 2016 Build thread
Old 11-19-2015, 09:32 PM   #124
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Thanks man. Means a lot. I'm not satisfied though (who is?) , want to get rid of some of that wheel well gap so I considered lowering an inch to close it. At the same time I want a lip kit so that's so low.
Think I finally decided to get meaty tires to cover the well and a lip kit.
stevesnj (11-19-2015)
Old 11-19-2015, 09:37 PM   #125
stevesnj
stevesnj's Avatar
I'd say a minor drop, eibach pro/TRD lowering. They are the same slightly under an inch and would make it so you could put a lip on too.
Old 11-19-2015, 10:58 PM   #126
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
I was researching Springs as well. Rce yellows . 08 or trd which is 1". Was going to go with trd but think I'll get the lip first to see how much I'm willing to commit after its on. Will be posting pictures here again once I got it to show the ground clearance since it's still stock height.
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
Aftermarket wheels with stock suspension Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-24-2013 05:08 PM
Stock TPMS's with aftermarket valves/wheels? Phaedrus29 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2012 01:18 PM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
