Old 08-17-2012, 02:25 AM   #1
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Stock TPMS's with aftermarket valves/wheels?
I have some tires arriving tomorrow for some Volk RE30s. The Volks came with valve stems. I'd like to move the stock TPMS's over to the Volks. Is that doable? Ideally I would use the Volk valve stems with the stock TPMS's. Does that work or do I have to use the stock valve stems? Will the stock valve stems even work with the RE30s?
Phaedrus29 is offline   Reply With Quote
Old 08-17-2012, 08:37 AM   #2
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
The valve stem is part of the TPMS sensor so you'll have to use them together but otherwise it shouldn't be a problem.
Old 08-17-2012, 12:18 PM   #3
Phaedrus29
Phaedrus29's Avatar
Thanks. Hrmmmm...the stock valves look pretty bad with my bronze wheels so now I need to decide if it's worth moving them over and maybe painting them, or just forgetting it and dealing with the TPMS light.
Old 08-17-2012, 01:18 PM   #4
neutron256
neutron256's Avatar
You could use electrical heat shrink tubing over the stems to change the look. It comes in a huge number of colors and sizes, and would probably be quicker and more durable then painting them.
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
Aftermarket wheels chopped onto Modellista 86 JDM-dono FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 32 12-20-2011 04:20 AM
Aftermarket wheels? Levi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-06-2011 07:19 AM
