Old 11-05-2015, 01:13 PM   #1
yuu
Drives: 2013 Raven Scion FR-S
TCS and slippage
Hey, I am not sure where to post this but recently my FRS has been driving really strange, it seems to have developed a wobble while traveling faster than 50MPH.
Whenever I turn it seems to catch, buck and turn extra sharp or wobbles through turns. It holds true going straight until a certain speed then occasionally wobbles but while going through turns, even if I go slow the car feels like it slips and the TCS kicks in, I can even take a corner at 25MPH and the tail will kick out, shake and TCS kicks in.
Any small bump i hit in the road TCS will go crazy.
I recently replaced the tires but this started happening just before I replaced the tires and is continuing with the new tires.
Does anyone have any ideas?
yuu is offline   Reply With Quote
Old 11-05-2015, 01:14 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Wheel speed sensor??
Old 11-05-2015, 01:18 PM   #3
yuu
Would the ABS light be on if the wheel speed sensor is damaged?
I do have TPMS light on, even though the tire pressure is fine.
Old 11-05-2015, 01:20 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
True for the ABS light. Probably wrong sensors in your new tires or they need to be programed
Old 11-05-2015, 01:31 PM   #5
yuu
thank you for your quick replies. Does the wrong sensor cause it to go a bit crazy like that? It has been a little scary to drive with TCS going crazy and turning being somewhat unpredictable.
Old 11-05-2015, 01:32 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah there are like 4 main TPMS types if I remeber right but not all work with all cars. It would only effect the TPM light on that dash and nothing else though.
I am off for lunch so no more quick responses haha. I hope someone else can chime in.
Old 11-05-2015, 02:27 PM   #7
ryoma
ryoma's Avatar
have you replaced your steering wheel and not orient the clock spring correctly? when was the last time you got an alignment? have you done any suspension work? check for loose bolts on suspension parts.
Old 11-05-2015, 03:52 PM   #8
yuu
Thank you for replying
Steering wheel has not been replaced but I think it has been a while since I have had an alignment, the last time I went to Toyota, about 5 months ago they did an inspection and said everything was good. No suspension work has been done but I also suspect that it is a possibility.
I recently got a new job where I drive over very rough road on my way to work, it is almost like driving on rocks I try to take it slow.
Old 11-05-2015, 08:47 PM   #9
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
If stability control (VSC) is being triggered, it's likely to be related to wheel speed sensors. These are pretty robust, but things happen.
Check the connector, the sensor ring, and the wire for damage (on all 4 corners).
Since you're driving on bad roads, it's possible that you kicked a rock into that area and damaged something. It's also pretty likely that your alignment has been thrown off.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 11-05-2015, 08:53 PM   #10
juliog
juliog's Avatar
Drives: 86
Perhaps a loose ball joint or some other suspension component. See if you can get an alignment or inspection at a shop with a good reputation for performance alignments and suspension work. Where are you located?
juliog is offline   Reply With Quote
Old 11-05-2015, 09:04 PM   #11
stevesnj
stevesnj's Avatar
Don't guess on this one, just go to the dealer and have them diagnose it.
My 2016 Build thread
Old 11-05-2015, 10:51 PM   #12
yuu
In the East Bay of the San Francisco Bay Area, near Oakland. Do you have any recommendation for here?
Old 11-05-2015, 10:53 PM   #13
yuu
wow this is very helpful, thank you. I will check it out this weekend.
Old 11-06-2015, 12:47 AM   #14
juliog
juliog's Avatar
Drives: 86
I can vouch for Elite Performance http://eliteperformance-us.com
slipping, tires, traction
Transmission Slippage? mikev77 Engine, Exhaust, Transmission 15 11-01-2015 09:29 PM
Gear slippage from 3-4 zypher10 Engine, Exhaust, Transmission 0 10-18-2015 08:42 PM
