#15 | |
| The Following User Says Thank You to swarb For This Useful Post: | LOLS2K (11-04-2015) |
#16 | |
You don't go to an oncologist when you have a heart problem. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | LOLS2K (11-04-2015), strat61caster (11-04-2015) |
#17 |
AutoX-10/10ths every run
OP stated "Budget really isn't an issue". I just made an additional suggestion based on what I read and my experience. I don't see how suggesting Penskes would be a useful suggestion since as I understand that's a $7,000 price point.
#18 |
Drives: DGM BRZ
and I was suggesting he consider "stretching" the budget and take a serious look at the Fortune Auto 500's and the Feal 441's. Both can be had for under $1500 and I can't find a negative comment or review of either anywhere.
I raced mountain bikes for years in a pro class and know a lot about tuning the suspension forks and shocks. I learned how to dial in high speed and low speed compression dampening. I felt the differences between different shock oils. However, the best decision I made when racing was to have a well respected company completely customize my shocks based on my weight, the bike, and how and where I rode. This type of attention to detail was expensive. If I had to pay full price, my front shock alone would exceed the cost of these coil overs! One other thing I've learned though the years is that suspension preferences can vary wildly. The NY state camp set his suspension up very soft with little compression damping, less air pressure, and fast rebound. Another friend who turned pro last year set up his suspension extremely stiff with LOTS of high speed and low speed compression dampening. Both riders were very fast! And loved their set-ups. They both won their categories last season. I thought both sucked and set my suspension differently -- lots of low speed compression, very little high speed compression, speed sensitive rebound set up on the slow side, and a spring rate on the softer side. I dominated my class when I last raced a full season. Our bikes each felt very different, and they were the exact same frames from the same company. What I like about FA is that you can talk to someone who should know what they are doing, and they will help you choose spring rates, range of dampening etc. The shocks will be set up based on what you tell them and how you want the car to feel. With all the other options in this range you will have to hope that the company designed them in a way that you like. You may love them, or hate them. Don't listen to much when someone raves about their shocks, they may have different preferences and driving style. Since I know pretty much nothing about setting up auto suspension, I plan on having a long conversation with someone at Fortune Auto and trust that they can get it right. After I really think about how I want the car to perform and am sure I can describe the characteristics to someone. |
| The Following 2 Users Say Thank You to BobBRZ For This Useful Post: | CSG Mike (11-05-2015), strat61caster (11-05-2015) |
#19 |
Drives: FR-S Whiteout
I'm not suggesting that they're suspension specialist, I'm only saying that they are very thorough and anal as engineers tend to be.
Intent > Content
cowardice is the mother of cruelty. |
#20 |
Drives: 2014 GT86
solidONE: but i often seen cases where having high skill level in seemingly similar area may lead to unbased overconfidence and wrong decisions on subject. Like how doctors often complain that worst patients ever are other doctors (of different field), as despite being of different specialisation they have unshakeable beliefs set in stone that they KNOW better then doctor that specialises in this field and treats them. Or how some competent plumbing specialist/engineer that designed high pressure lines in high-tech manufacturing factories made some rather stupid/inefficient choices when was doing for hobby liquid cooling for this PC.
| The Following 2 Users Say Thank You to churchx For This Useful Post: | CSG Mike (11-05-2015), strat61caster (11-05-2015) |
#21 | |
Both are nice plates though. I don't think I'd consider any other. I would suggest thinking about the T0s as well. They're an easy, durable, and really fun set-up not far from your price range. I'm not sure I'd look at them as overkill...they'll handle better and ride about the same. Yes more money though. The Bilstein + Tarmac springs is a good solution too. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | CSG Mike (11-05-2015) |
#22 |
Drives: 10 Series Scion FR-S
I have Swift spec-R springs (similar to the RCE tarmacs in spring rate) with koni shocks, the adjustability in the koni shocks has given me the freedom to match the damping to the spring rate to the point I use my current damping setup for DD and track with no issue... I currently drive it with about 1.5 turns from soft (out of 2.25 turns). If I go full soft I can have a ride that's close to and maybe a little softer than stock.
I already have about 4K miles on my setup. |
#23 | |
Drives: '13 FRS - STX
We're talking about trying different combinations of 1-click 2-click 3-click and a couple manuals on the subject, it doesn't take a rocket scientist to determine you are unhappy with how a damper performs, whether your right or wrong on it's true performance. As above suspension setups can be very preferential. |
| The Following User Says Thank You to strat61caster For This Useful Post: | CSG Mike (11-05-2015) |
#24 | |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: | cdrazic93 (11-05-2015), Racecomp Engineering (11-05-2015), strat61caster (11-05-2015), Trettiosjuan (11-06-2015) |
#25 |
Junior
Drives: a car
One of the reasons why i like Andy and RCE, that was a completely unbiased vendor post purely aimed at helping, rather than product pushing
I would like to see a good breakdown review of these two options.
| The Following 2 Users Say Thank You to cdrazic93 For This Useful Post: | Racecomp Engineering (11-05-2015), Trettiosjuan (11-06-2015) |
#26 | |
Intent > Content
#27 |
Drives: GT86
Anybody near RCE/CSG should feel fortunate to be able to use their services.
Because I'm not I have the Flex A incoming because of the damper adjustability. If I was, I'd go for Bilstein B8 with custom straight wound springs with matching valving. Relative high spring rates and almost stock height for maximum bump stroke performance, B8 for the high rate spring that has less droop but extends quick because of the constant rate. In a Perfect World, it had the hydraulic bumpstop from the A's. A twin that eats bumpy forest roads for beakfast. And shows all those stance fashion devices how to take a speedhump at (not twice but like ten times their) speed... Last edited by Trettiosjuan; 11-06-2015 at 03:56 AM. |
| The Following User Says Thank You to Trettiosjuan For This Useful Post: | Racecomp Engineering (11-06-2015) |
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 09:33 PM |
| Bilstein B14 vs Tein Flex vs ISC N1 vs MCA Blue (Coilovers) | xkwizt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 02-24-2015 05:10 PM |
| Switched from RCE Yellows to Bilstein B8/RCE Tarmac Springs | was385 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 01-23-2015 11:19 PM |
| Review: Bilstein B8 + RCE Tarmac lowering springs. | Turkish | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-04-2014 02:30 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 01:10 PM |
