Old 11-04-2015, 07:43 PM   #1
ElPablo
Drives: 2015 Brz Premium
Does this sound like an exhaust leak?
[ame="https://www.youtube.com/watch?v=yhvq8B8Pcno"]BRZ pulse jet cold start - YouTube[/ame]
I have a similar setup, and my sounds awful like that on a cold start. I know I have at least one exhaust leak. My question, does the exhaust in the you tube link sound remotely normal, or sound like it has an exhaust leak?
Thanks, my google efforts/searches for exhaust leaks, hasn't put anything obvious in front of me for what they sound like.
ElPablo is offline   Reply With Quote
Old 11-04-2015, 07:46 PM   #2
phrosty
Are you running catless?
Exhaust leaks usually sound like a ticking noise when idle.
phrosty is offline   Reply With Quote
Old 11-04-2015, 07:56 PM   #3
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Take a video from the front of the car, we can't hear shit over the sound of exhaust leaving through the proper orifices in that video.
Sounds normal out back to me though
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
FRS Justin (11-04-2015)
Old 11-04-2015, 08:04 PM   #4
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Catless cold starts are loud as hell unless if you tune them out.
jawn is offline   Reply With Quote
The Following 2 Users Say Thank You to jawn For This Useful Post:
FRS Justin (11-04-2015), kch (11-05-2015)
Old 11-05-2015, 12:11 AM   #5
Originally Posted by ElPablo View Post
.........................does the exhaust in the you tube link sound remotely normal, or sound like it has an exhaust leak?
Well, I reckon, the only way it could sound like an exhaust leak is ...... if the leak is at the manifold, because someone didn't hook up the exhaust pipe.....
Old 11-05-2015, 11:00 AM   #6
ElPablo
Thanks, and sorry for not being more clear.
That isn't my car, mine just has almost the exact same setup and sounds the same.
I have a jdl uel header (catless), jdl overpipe, and jdl ultra quiet front pipe (high flow cat and resonated), the rest is stock, and oft stage 2 tune
What I was unsure of is how much exhaust leaks affects the exhaust sound. I figure it would change some depending on the severity of the leaks (different psi, etc in the muffler, may change the sound is my thinking).
I know I have to fix my exhaust leaks. Just trying to figure out if that would fix/alter the exhaust sound I hate. If not, need to order whatever other parts I need fix that (would like to do both at the same time, I'm too old and fat to be laying under my brz. heck, my wrangler on the ground has more clearance underneath than my brz on 6 ton jack stands fully extended). Prob should just order a a q300 or a perrin catback and call it a day. Or go all in and embrace the obnoxious sound and order a berk muffler delete.
Anyway, thanks, and thanks for not ragging on me too bad (I deserve it )
Old 11-05-2015, 11:02 AM   #7
ElPablo
The kid tried to get me to start it up that way... and with only the header hooked up.
Old 11-05-2015, 11:09 AM   #8
jawn
jawn's Avatar
Couple of things: it's still not clear if you have an exhaust leak. Cold starts are loud without a cat in the header. You can tune this out with your OFT. The loud noise in that video is the massive overlap that these cars have built-in to their startup logic to heat up a cat that you no longer have in your headers. For instance (not my car, but you get the idea):
[ame="https://www.youtube.com/watch?v=7ZM5d_7c5Xo"]Borla UEL headers with stock exhaust - YouTube[/ame]
That's basically how all cold starts sound like with a catless header, until you tune out the cold start logic. Exhaust leaks aren't necessarily loud. They're usually a hissing or a whistling noise.
Also, have you been datalogging with your OFT? LTFT values can be pretty wonky if you do have an exhaust leak.
Old 11-05-2015, 01:07 PM   #9
ElPablo
Thanks,
I 100% know for a fact I had and may still have (heat cycles may have fixed it) at least one exhaust leak. I could feel it and it doesn't make a sound at the doughnut gasket. I also need to retorque my headers, will listen check for exhaust leaks then (funnel and some heater hose). I just wasn't clear if exhaust leaks would cause the exhaust sound to change, in addition to making hissing sounds, ticking noises. My leak around the doughnut gasket was sealing very close to when the cold start up was disappearing. I'll have to get it back up on stands Saturday to check if it's still leaking there.
I was expecting a loud cold startup due to heating up the cat for emissions. I wasn't expecting it to sound like my car has salmonella and e coli food poisoning all at once. Was trying to see if the correlation of the known exhaust leak had any factor in the tone of my exhaust sounding like crap on cold startup. I just worded it all very poorly.
So, I think my answer is small exhaust leaks don't change the exhaust sound. (obviously, massive holes in the exhaust would)
I think I'll tell my wife a jackson super charger is the obvious way to go to change cold starts.
Old 11-05-2015, 01:34 PM   #10
ElPablo
Since it's been made clear small exhaust leaks, don't change exhaust tone... and if the wife doesn't go for the jackson supercharger "fix". I'll just adjust my cold start "Ignition Timing Post Start" settings.
Again, thanks.
Exhaust leak? Joeycokeboy Engine, Exhaust, Transmission 6 06-05-2015 12:29 PM
Exhaust leak? Jman1759 Engine, Exhaust, Transmission 4 11-29-2014 11:11 PM
Exhaust Leak sound on new FRS - low speeds Koa Issues | Warranty | Recalls / TSB 4 11-09-2014 08:50 PM
Exhaust Leak help? ray7792 Engine, Exhaust, Transmission 4 07-04-2014 01:08 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 12:59 PM
