Old 06-05-2015, 11:48 AM   #1
Joeycokeboy
Drives: 2014 scion frs
Exhaust leak?
I recently installed my catback and when i out my overpipe back on i was missing a flange. So now i only have one flange in my overpipe. Ive noticed a ticking noise when i rev it and while i drive its so loud it sound idk if its that or from and injector. I know the boxer is a noisy motor but this is really distintive and none if my fellow frs friend have this. Any thoughts on what a slight leak would sound like?
Joeycokeboy is offline   Reply With Quote
Old 06-05-2015, 11:53 AM   #2
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
You're missing a flange or a gasket? If you're missing a flange, that's the entire end of the pipe where the bolts/nuts and the pipe pieces come together sandwiched with a gasket.
Catbacks are the back of the exhaust which is an axleback section combined with a midpipe. The overpipe connects to the header and front pipe.
Header -> Overpipe -> Front Pipe -> Midpipe -> Axleback(muffler)
Front to back of the car.
Slight leaks sound like a ticking noise. If you put a blank sheet of paper up to the flange, it would blow and move. Then you know you have an exhaust leak.
2016 Camaro SS is offline   Reply With Quote
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
Bergen23 (06-05-2015)
Old 06-05-2015, 12:04 PM   #3
Joeycokeboy
Sorry im missing a gasket had my terms wrong
Old 06-05-2015, 12:19 PM   #4
Bergen23
Drives: '15 Halo FR-S
Just go to the dealership, get another gasket, install. Problem solved. Would take you about 30 minutes to do if you have all the required tools.
Bergen23 is offline   Reply With Quote
Old 06-05-2015, 12:21 PM   #5
kch
Senior Misanthrope
kch's Avatar
Slight leak typically sounds like a lawn sprinkler. Like this, but a little faster (skip to 39s): [ame="https://www.youtube.com/watch?v=KsxHY7oPcjg&t=38s"]Best Lawn Sprinkler - The Impact Sprinkler - YouTube[/ame]
It's particularly noticeable when you're driving next to a wall.
Old 06-05-2015, 12:24 PM   #6
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
Lol why install an exhaust without a required gasket, you're asking for a leak and now you have more work to do to take it off and put the gasket in
Romanov is offline   Reply With Quote
Old 06-05-2015, 12:29 PM   #7
Joeycokeboy
I took my old exhaust off and gave it to my friend and when i put my new one on i got jipped a gasket and it was midnight so i told myself ill fix it another time but now that i hear this noise im going to fix it
Openflash Header exhaust leak JB86'd Engine, Exhaust, Transmission 27 03-02-2015 11:15 PM
Exhaust leak? Jman1759 Engine, Exhaust, Transmission 4 11-29-2014 11:11 PM
Exhaust Leak help? ray7792 Engine, Exhaust, Transmission 4 07-04-2014 01:08 PM
Exhaust leak. J8boston8j Engine, Exhaust, Transmission 17 10-15-2013 08:09 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 12:59 PM
