Old 11-02-2015, 11:20 AM   #1
Vroomin86
Drives: 2015 Fire
Replaced liquids with motul 300.... Car stalls...
Hey guys looking to see if anyone might have some advice while I run the CEL codes.
Swapped over both tranny and diff fluids to motul 300. A day or two later the idle started sounding a little weird. Like a Diesel engine or if something was loose (slight knocking but only at idle)
Last night I drove the car and at a red light it bugged rough idle and boom shut off... any ideas?
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
Old 11-02-2015, 11:35 AM   #2
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
Any intake mods?
Dirty/BAD MAF can do that
#TrackDayBro
Kuri is offline   Reply With Quote
The Following User Says Thank You to Kuri For This Useful Post:
Vroomin86 (11-03-2015)
Old 11-02-2015, 11:45 AM   #3
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Sounds like your motor has no oil.
TRAKRAVN is offline   Reply With Quote
The Following User Says Thank You to TRAKRAVN For This Useful Post:
Old 11-02-2015, 11:47 AM   #4
Fred E
Drives: WRB BRZ
There is no way transmission or differential fluids would have any affect on your car's idle, but an intake modification or dirty MAF sensor as previously mentioned might. What are the CEL codes?
Fred E is offline   Reply With Quote
The Following User Says Thank You to Fred E For This Useful Post:
Old 11-02-2015, 01:54 PM   #5
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
If that's the only thing you've changed for sure, double check and make sure your trans and diff aren't leaking. The fluid change itself is highly unlikely to cause that, unless the fluid leaked out and is causing significant friction. What codes came up?
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
Old 11-02-2015, 01:55 PM   #6
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
unless you changed your engine oil with motul gear oil.....there should be no connection between those two things...
driftartist is offline   Reply With Quote
The Following 2 Users Say Thank You to driftartist For This Useful Post:
fumanchu1 (11-02-2015), Vroomin86 (11-03-2015)
Old 11-02-2015, 01:56 PM   #7
ModBargains.com
ModBargains.com's Avatar
+1
We've installed Motul fluid here quite frequently into the differential/transmission and never had any issues whatsoever. The issue here likely is what everyone else is saying, it sounds more motor related than transmission.
ModBargains.com is offline   Reply With Quote
The Following User Says Thank You to ModBargains.com For This Useful Post:
Old 11-02-2015, 01:57 PM   #8
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Cool
Oh man I love Detective story!
The Following 4 Users Say Thank You to chaoskaze For This Useful Post:
GotBRZ1691 (11-02-2015), humfrz (11-02-2015), MisterSheep (11-02-2015), Vroomin86 (11-03-2015)
Old 11-02-2015, 02:13 PM   #9
OK, OP .......... what is ........"the rest of the story" ..... ??
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Kuri (11-04-2015), stugray (11-02-2015), Vroomin86 (11-03-2015)
Old 11-02-2015, 05:26 PM   #10
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Let me give it a shot. OP did buy GEAR 300 Motul oil but accidentally put his prune juice in the car and drank the Motul, so his engine died and OP has not responded because well he drank Motul Gear 300 and.... well.... he isn't a diff or a tranny... or wait... maybe he is a tranny who knows these days.
fumanchu1 is offline   Reply With Quote
The Following 2 Users Say Thank You to fumanchu1 For This Useful Post:
go_a_way1 (11-02-2015), soulreapersteve (11-03-2015)
Old 11-02-2015, 09:26 PM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
My guess he filled the tranny and diff by way of the engine oil fill.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 11-03-2015, 01:14 AM   #12
Hey guys looking to see if anyone might have some advice while I run the CEL codes.................
Bad gas, maybe ....... ??
Old 11-03-2015, 01:00 PM   #13
Vroomin86
Drives: 2015 Fire
You nailed it, best prune juice I ever drank
Well the results are in..... The doctor wrote "P000A" ~ A camshaft position slow response bank 1 ......
I don't have any intake mods other than a drop in filter, no engine mods other than the fluid change, which was done at the dealership and I have no leaks.
So is it a total loss or can it be buffed out??
2015 FireStorm FRS
Old 11-03-2015, 02:03 PM   #14
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
Sounds like an issue from the unofficial CEL/SL/Idle thread that many people have been having. I threw a P000B code a few months back, same issue but different bank.
Dealership ended up replacing OCV for free and it fixed my problem. Contact your dealership for repair if you are still within warranty
BAMF86 is offline   Reply With Quote
The Following User Says Thank You to BAMF86 For This Useful Post:
Kuri (11-04-2015)
motul 300 vs motul 300ls about to buy some need help. NickFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 03-24-2016 10:51 PM
When to check Liquids (oil & coolant) qbzee007 AFRICA 40 06-25-2015 02:47 PM
Car stalls on highway, force inducted ... No cell!? RD1428 Forced Induction 15 05-21-2015 09:51 PM
Automatic FR-S randomly stalls when Idling LzT AngeL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 12-15-2014 08:31 AM
Car almost stalls but clutch is all the way in when stopped LaertesSon Engine, Exhaust, Transmission 11 05-13-2014 05:55 PM
