Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 06-09-2014, 04:36 AM   #1
qbzee007
qbzee007's Avatar
Drives: 97 Audi A4 1.8 Avant '13 Subaru BRZ
When to check Liquids (oil & coolant)
Hi Guys,
My BRZ has about 7000km on the clock and I have a sneaky suspicion that it is consuming oil.
I just want to find out what time is best to check the oil. Is it when cold or after it has warmed up.
The reasons I ask this are two fold.
1. it seems the water level is best checked after the engine is warm as the water recedes in the reservoir over night and gets to the Full mark once warm.
2. A service personnel at Subaru said the oil is best checked when the car is cold.
So I am quite confused.
Thanks in advance.
P.S Is it normal that the car be consuming a significant amount of oil at such low mileage?
qbzee007 is offline   Reply With Quote
Old 06-09-2014, 05:06 AM   #2
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
I don't think so.
I've done 37000 kms and I've never had to top up any fluids ever.
But I do change oil every 7500 kms because I track my car and it's S/C.
I check all fluid levels cold, and always at home rather than the filling station.
YMMV
Fish Eagle is offline   Reply With Quote
Old 06-09-2014, 05:22 AM   #3
Die$eL
Die$eL's Avatar
Drives: Toyota MR2 Spyder Turbo
Best is a few minutes after you park.
So the oil is still warm and it has had a few mins to drain back into the sump.
I try to do both. Check when its cold and when its hot.
Mine also does the same where the coolant level fluctuates depending on engine temp.
As long as its between the min and max at both times its fine by me
Die$eL is offline   Reply With Quote
Old 06-09-2014, 06:02 AM   #4
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
I always check when cold - never needed to top up oil, and coolant sitting on the cold mark.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 06-09-2014, 09:32 AM   #5
qbzee007
qbzee007's Avatar
thanks guys. I will keep an eye on it and see
Old 06-09-2014, 09:48 AM   #6
sav
sav's Avatar
Cool, I forgot to mention - the coolant did fluctuate quite a bit in the beginning. Just top up with distilled water or coolant from Subaru when cold.
95RON SAV Tuned
Old 10-13-2014, 04:17 AM   #7
NamSin
Drives: Toyota 86 Auto Satin Pearl White
Hi,
Does anyone have the part number for the Toyota Super Long Life BLUE coolant in South Africa?
Search the forums and found a discussion on it on the oil thread, but no part numbers.
NamSin is offline   Reply With Quote
Old 10-13-2014, 05:00 AM   #8
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
You can get from Toyota but get ready to get a big tin thereof (5l I think) and over R300.
Vic_RSA is offline   Reply With Quote
The Following User Says Thank You to Vic_RSA For This Useful Post:
NamSin (10-13-2014)
Old 10-13-2014, 05:07 AM   #9
NamSin
Thanks for the quick feedback - called 2 local dealers and they are adamant that the 86 uses the standard red Toyota coolant - do you maybe have a part number or can you recommend a dealer I can call?
Old 10-13-2014, 07:06 AM   #10
Naughty
Drives: RunX RSi
Hey Dude
Toyota Strydom park know the coolant the 86 should use. THey only sell it in 5l and its Blue i think.
I enquired about it but did not take down the part number.
Alternatively, check with Subaru.
Naughty is offline   Reply With Quote
The Following User Says Thank You to Naughty For This Useful Post:
NamSin (10-13-2014)
Old 10-14-2014, 02:49 AM   #11
CWP68
CWP68's Avatar
Drives: Toyota 86 Supercharged
Dealers don't do themselves any favours sometimes. I mean I'm no expert on the subject but it is definitely blue!
CWP68 is offline   Reply With Quote
Old 10-14-2014, 09:52 AM   #12
qbzee007
qbzee007's Avatar
Mine is Blue.
Old 10-15-2014, 04:46 AM   #13
sav
sav's Avatar
If it's 5l I'm assuming it's premix?
95RON SAV Tuned
Old 10-15-2014, 04:54 AM   #14
sav
sav's Avatar
Mine is Blue.
Same here.
95RON SAV Tuned
Coolant, Anyone tried this?? stevo_12v Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-27-2016 04:50 PM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Where did my coolant go? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 1 11-02-2013 11:46 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
