Old 05-21-2015, 09:35 AM   #1
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
Car stalls on highway, force inducted ... No cell!?
So I am driving to work this morning and after about 15 min my speedo needle went all the way down, the ABS light came on, traction control light came on and CEL on.. Lost power the engine turned off so had to pull over.. I have a blue tooth reader and no cell pops ups up. When I try to turn on the car, it will tell me how much gas there is but the temperature gauge doesn't move, and I know the engine is warm... I have a SBD turbo kit with the off the shelf tune for OFT.
I was having CEL P0068, P0451
I swapped the 3 bar map sensor for the stock one and the cell went away, but then it wasn't the correct one so I used the stock map sensor until I get a new one ( the supplied on didn't seem to work)
AFR looked good and I wasnt boosting when it shut off..
Clutch seems to still be working
Car won't even turn, battery is good
Oh and waiting in my car for a tow truck right now
RD1428 is offline   Reply With Quote
Old 05-21-2015, 10:14 AM   #2
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Try putting your 3 bar map sensor back on then start your car. Sounds like you need a new tune.
Cessblood is offline   Reply With Quote
The Following User Says Thank You to Cessblood For This Useful Post:
raven1231 (05-21-2015)
Old 05-21-2015, 10:17 AM   #3
raven1231
Yeah, I'd put the sensor back on and get a tune that's not an OTS tune.
Old 05-21-2015, 10:29 AM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Wrong MAP sensor will make the car not work. You may have been able to start it (most of the times car wont even start), but even after start it will not perform well. The MAP sensor values are a critical input to the ECU.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 05-21-2015, 12:34 PM   #5
RD1428
RD1428's Avatar
Thanks guys
Old 05-21-2015, 04:32 PM   #6
RD1428
RD1428's Avatar
I can't even try to reflash my car, or look at diagnostics oft keeps saying error.. Fml
Old 05-21-2015, 04:38 PM   #7
IBill4You
Drives: 2015 Subaru BRZ
Pull both your map and maf turn engine over. Replace sensors start car drive away get new tune. What year is your vehicle
Nvm I see it is a 2013.
IBill4You is offline   Reply With Quote
Old 05-21-2015, 05:06 PM   #8
RD1428
RD1428's Avatar
Won't even turn over
Old 05-21-2015, 05:10 PM   #9
IBill4You
damn man. If you have any tools with you at all maybe try pulling the neg battery terminal for a min. Its gotta be better than being stuck as long as you're in a safe location. Good luck man
Old 05-21-2015, 06:28 PM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@shiv
Old 05-21-2015, 07:10 PM   #11
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Have you had your injector covers off at any point?
The Racers Line is offline   Reply With Quote
Old 05-21-2015, 07:13 PM   #12
RD1428
RD1428's Avatar
EFI 1 (ctrl) fuse keeps blowing,
and yes I took it of but re-installed
Old 05-21-2015, 07:18 PM   #13
RD1428
RD1428's Avatar
@The Racers Line
The Following User Says Thank You to RD1428 For This Useful Post:
The Racers Line (05-21-2015)
Old 05-21-2015, 08:13 PM   #14
Poodles
Drives: 2015 Series.Blue
Remember reading about some wiring getting frayed and causing a short in that area a while back.
If it's popping a fuse, there's a short and it needs to be found.
Automatic FR-S randomly stalls when Idling LzT AngeL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 12-15-2014 08:31 AM
Car almost stalls but clutch is all the way in when stopped LaertesSon Engine, Exhaust, Transmission 11 05-13-2014 05:55 PM
Anyone using a universal cell phone holder? swift996 Electronics | Audio | NAV | Infotainment 4 12-16-2012 06:13 PM
Cell Phone Provider WRXGuy1 New England 15 11-06-2012 10:27 AM
Cell Phone Interference akuhei Issues | Warranty | Recalls / TSB 3 10-11-2012 04:35 PM
