Old 10-24-2015, 12:52 AM   #1
cookiesowns
Drives: WRB BRZ Series.Blue
P000A AVCS check engline light?
Hey guys,
My car threw a check engine light a few days ago. Had rough idle after a drive. Idle sort of stumbled and it then threw the light.
After some drive cycles its disappeared and the car is running great. Logs look good.
Edit: Lol that typo.
cookiesowns is offline   Reply With Quote
Old 10-24-2015, 01:58 AM   #2
Sorry, I missed the question ........
Old 10-24-2015, 02:15 AM   #3
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by cookiesowns View Post
Hey guys,
I would check for exhaust leaks, do you have a catless header without a tune? Different intake without the MAF being scaled?
Also i'm friends with you on steam LOL. I'm !aZ
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 10-24-2015, 02:45 AM   #4
steve99
Drives: FT86
if it comes back get it sorted
see here P00A is cam position sensor code but can be caused by other stuff
it might just be cam position sensor need clearance adjusting believe their is tsb
but could be nasty
http://www.ft86club.com/forums/showp...postcount=2911
Old 10-24-2015, 02:48 AM   #5
cookiesowns
I noticed it happened once after I parked the car outside for a day. ( Was cold and humid ).
The same day it occurred oil temps were also hotter, around 185C ( I have JRSC oil cooler )
My car is otherwise stock, also on stock tune. D00C.
Hasn't come back since then, car runs good, other than stock tune knocking down low..
Help check engine light Frsultramarine15 Scion FR-S / Toyota 86 GT86 General Forum 8 06-03-2015 04:18 PM
Engine Check Light..HELP AZOOZ_95 Engine, Exhaust, Transmission 10 02-09-2014 04:20 PM
Check engine light. Help!!!!! sf86 Issues | Warranty | Recalls / TSB 2 06-05-2013 04:51 AM
Check engine light? czar07 AUSTRALIA 0 09-01-2012 03:50 AM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 10:50 PM
