Old 10-21-2015, 01:09 AM   #1
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Custom GT 300 hood vents/heat managment
I want to know if anyone has experience or thoughts on cutting into the oem aluminum hood for venting/heat management purposes (specifically styled like the gt300 perhaps?) I know that @Reaper has done something similar in his own thread.
The reason why I ask is because most aftermarket hoods (Seibon etc.) are actually heavier than our oem ones! Unless you're using a pure carbon process (not carbon over fiberglass) those hoods are a pass for me.
I know that aluminum is traditionally a harder metal to form and bend into shape, so I want to know if this is feasible. The design would also need to be functional and take into account areas of high and low preasure as air passes over the hood, so as to extract heat from the engine bay.
Thoughts? Sound off. See pictures for reference
kuczynskika is offline   Reply With Quote
Old 10-21-2015, 02:20 AM   #2
swarb
Cutting metal, then bending it, then welding a triangle shaped piece to reinforce it.
There is also the reinforcement bars under. And then trying to get them to be symmetrical...
All that labor, paint, etc , it is cheaper to buy a hood with vents in them.
Or cut a hole and put a vent/duct in the hole.
It's only cheaper if you have free welding and fabrication.
Old 10-21-2015, 02:26 AM   #3
kuczynskika
Cost isn't so much an issue here. I'm more interested in maintaining a light hood and incorporating heat management. Wouldn't even have to be as intricate as the GT 300.
Old 10-21-2015, 03:25 AM   #4
swarb
Here is the cut, bend, weld method. The side reinforcements must be made.
Or the easy way and cut a hole and put a vent/duct/scoop on it.
The Following 2 Users Say Thank You to swarb For This Useful Post:
8R6 (10-21-2015), van_fc3s (10-21-2015)
Old 10-21-2015, 03:27 AM   #5
swarb
Someone on here recently used the stock hood with some ducts. I don't remember where exactly.
Old 10-21-2015, 08:20 AM   #6
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
s2000 vent
here is the thread
http://www.ft86club.com/forums/showthread.php?p=2388294
malubawla is offline   Reply With Quote
Old 10-21-2015, 12:59 PM   #7
kuczynskika
Originally Posted by malubawla View Post
Yea I already mentioned that one in my original post. Thanks tho
Old 10-21-2015, 01:00 PM   #8
kuczynskika
Nice, that looks cool too. Shit ton of fabrication for sure tho. Hmmmm
heat management, CF hood alternative Reaper Forced Induction 70 07-05-2017 02:22 AM
SCION FR-S Custom Fit Sun Shade Heat Shield berjaya2015 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-09-2014 02:24 PM
Seibon TS hood heat shield texasbound972 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2014 12:08 PM
raising the hood to combat the heat? BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 1 04-03-2014 01:41 AM
Hood Vents and Weather Cjymiller Cosmetic Modification (Interior/Exterior/Lighting) 13 10-20-2013 02:31 PM
