Old 09-12-2015, 09:14 PM   #1
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
heat management, CF hood alternative
When tracking the FRS/BRZ under boost heat management because a concern. Larger radiator, oil cooler etc are the initial reactions to the problem. Some of us have modified the front bumper in an attempt to increase airflow. But the limitation to the system is not air INTO the engine bay its air OUT of the engine bay.
Proof of this can be seen by hood flutter even at highway speeds. A vented hood in my opinion is a must. For aero and cooling reasons. But some/most weigh MORE than the factory hood and dont generally fit as well as OEM. I also have a tuff time stomaching the price of a poorly fitting heavier than factory hood that i still have to paint match.
Robispec an early pioneer in the frs tracking community was thinking the same thing and louvered his hood. Sometimes hard to find someone who can do that. But i searched the internet and found Trackspec Motorsports.
((I am not affiliated or sponsored by them))
They make a simple low cost rivet in hood vent that's used by hundreds of time attack/NASA racers in the southeast. I literally see these things on corvettes, camaros, BMW's, porsches etc all the time.
They sent me a vent kit for the S2000 and asked if i would get some feedback from the FRS/BRZ community. Their vents are in the mid 300$ range and they make many sizes. They come with a simple template i measured from the four corners of the hood and taped it with painters tape. Drilled a hole in at one corner to insert a cheap fine tooth airsaw and cut out the template. Laid in the vent drilled a few more holes and put in some rivets. I had a significant reduction in front lift, 30+* drop in under hood temps and my BOV and other turbo noises are louder now. (ha) For 1/3 the cost of some CF vented hoods.
Old 09-12-2015, 09:52 PM   #2
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
thats cool as hell
RocketBunny FRS // Phantom ESC // OFT x E85
Dallen is offline   Reply With Quote
Old 09-12-2015, 09:54 PM   #3
Reaper
Reaper's Avatar
Drives: violent
thanks! i was very impressed with it myself in function, price and how it looks now.
Old 09-12-2015, 10:01 PM   #4
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
where are they selling?
Old 09-12-2015, 10:06 PM   #5
Reaper
Reaper's Avatar
Drives: violent
tracspec motorsports. i contacted them via their facebook page https://www.facebook.com/Trackspec-M...5927/timeline/ since the s2000 vents were not on their website yet http://trackspe.nextmp.net/
Old 09-13-2015, 02:27 PM   #6
Reaper
Reaper's Avatar
Drives: violent
@nelsmar @csgmike
Old 09-13-2015, 03:12 PM   #7
mrk1
Drives: Sterling BRZ Ltd
I've been wanting to go this route as well, cut vents not a CF hood.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 09-13-2015, 03:46 PM   #8
nelsmar
I considered doing this at one point... I know some other companies have been looking into producing some rivet install parts. I have also been considering louvering the hood for a long while now... But for the price of these vents I think I would rather louver the hood even though this would probably be a bit more beneficial but it stands out so much more on a street car than some louvers!
A lot of the CF hoods also have something that blocks air, or the edge going into the bay may disrupt flow. The ones you installed actually go above the hood line which should help evacuate in the way a wing works to lift an airplane up. I am kind of surprised that there doesn't seem to be any manufactures focused on making a functional evacuation hood. Putting a heavier carbon hood that doesn't dissipate heat as well as aluminum is "meh". I mean sure the vents they add nullify the fact that carbon doesn't help with heat conduction but.. =/
I was also considering just cutting out some panels on my hood and adding in a mesh so it didn't stand out too much but by not having a leading edge you don't get the benefit of the high velocity air going over the hood helping siphon the air out of the bay.
If they had a more subtle looking setup or if I had a black car (hah)... I would be more open to giving a setup like this a try! But my car is a street car and that looks wayyyyy too aggressive for me =(
My flickr - Canibeat
Local magazine scout
Old 09-13-2015, 04:02 PM   #9
Reaper
Reaper's Avatar
Drives: violent
I tested louvers in a wind tunnel and came up with the same results robispec did. You would have to do the whole hood for them to work. They are not very efficient at the angle our hood is at.
Old 09-14-2015, 04:45 AM   #10
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
U r my hero!! @CSG Mike
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 09-14-2015, 05:50 AM   #11
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
We installed those vents in our carbon fiber hood and fenders for added venting. We've had nothing but great results.
crazyfrenchbiker is offline   Reply With Quote
Old 09-14-2015, 12:17 PM   #12
crazyfrenchbiker
Hot Lava 6MT
Here's a picture of the vents on the race car.
Old 09-14-2015, 01:41 PM   #13
Reaper
Reaper's Avatar
Drives: violent
@crazyfrenchbiker which fender vents did you use from them?
Old 09-14-2015, 01:46 PM   #14
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I like. I may get a set for next summer. Though I would prefer smaller ones I could put closer to the front of the hood, over the belts. Usually that area has lower pressure than further back on the hood.
Seibon TS hood heat shield texasbound972 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2014 11:08 AM
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc) glamcem Forced Induction 56 08-25-2014 06:07 PM
Top half car covers for cabin heat management on track dp1 Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2014 11:08 AM
raising the hood to combat the heat? BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 1 04-03-2014 12:41 AM
Avo turbo heat management on track ICantAffordAnLFA Forced Induction 18 09-09-2013 11:00 AM
