Old 10-18-2015, 09:40 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
How cold is too cold for E85?
I have an OFT and was running Stage 2 UEL E85 tune a while back. However, when the temps starting dipping into the 50's I started getting some cold start issues. I'd have to crank it a couple of times and once it acted really weird on warmup with the throttle going all over the place. That kind of freaked me out, so I switched back to 93. The extra power from E85 was really nice, but I'm worried to keep running it now. What do you guys do when it starts to get cold?
smg1138 is offline   Reply With Quote
Old 10-18-2015, 09:46 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Looks like there's a tune tweak to get it to fire while pretty cold (21F).
http://www.ft86club.com/forums/showp...1&postcount=40
Or you can switch to 93 for the winter. A lot of folks I know do.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
smg1138 (10-18-2015)
Old 10-18-2015, 09:58 PM   #3
steve99
Drives: FT86
I would use @Waynos cranking tables here
in this post
http://www.ft86club.com/forums/showthread.php?t=83945
if you still have problems when its rearly cold add a gallon of petrol as well
Old 10-18-2015, 10:49 PM   #4
Abe1120
Drives: 2015 scion frs
its been getting pretty cold around here in illinois ive seen frost in the morning when i go to start my car up for work and i havnt had any trouble with any start ups yet. any reason why?
Abe1120 is offline   Reply With Quote
Old 10-18-2015, 11:03 PM   #5
steve99
Drives: FT86
depends a lot on E% if you have high E5 like us E90, then you get start problems pretty early on standard oft crank tables.
If your arround E70 you will be pretty good down to about 40-50F.
if you mod the crank tables as per wayno post then you will be good even in cold temps on E70
Old 10-18-2015, 11:47 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I made some mods to my startup tables and could get it going in 40F with one or two turns of the key. That was with Propel e85, which seemed to be actual e85. With a gallon or two of 91, you should have little trouble with the OFT tune.
Old 10-19-2015, 01:20 AM   #7
smg1138
smg1138's Avatar
in this post
Sorry, dumb question. Can I use the BIN's in Wayno's zip file directly or do they need to be edited in Romraider first?
Old 10-19-2015, 02:05 AM   #8
trdric
Drives: fr-s
I was able to start the car at -10 C last year without much cranking with the OTS tunes. but Waynos table are the way to go
trdric is offline   Reply With Quote
Old 10-19-2015, 02:07 AM   #9
jawn
jawn's Avatar
I think you only need the E85 cranking tables.
And you should most definitely DO NOT directly use that bin. Those are example files, and have a wide range of changes that you may or may not need. And they're for an Australian automatic transmission car.
Trettiosjuan (10-20-2015)
Old 10-19-2015, 03:42 AM   #10
phrosty
I've had no problems cranking at 40F using Wayno's tables. Not sure if I'll want to risk it when things get below freezing.
phrosty is offline   Reply With Quote
Old 10-19-2015, 03:56 AM   #11
steve99
Drives: FT86
unless their is one of waynos roms that matches your tune and rom calibration id, you will have to transfer the trables from waynos roms to your rom calid
Old 10-19-2015, 04:57 AM   #12
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
E85 start easily above 5C
E100 start easily above 15C
Toyota86.ir is offline   Reply With Quote
Old 10-19-2015, 09:31 AM   #13
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
I had a noticeable pop this morning when starting with E85 right at 40*. This will be the last tank I run until it warms up again. The loud pop really worries me as it sounds like detonation (note it only did once when starting up). This is the coldest day of the week for us, as the rest will be in the 60-70 range, so I'll run it out and put 93 in for the winter.
Chad11491 is offline   Reply With Quote
Old 10-19-2015, 12:59 PM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
Detonation is called pinking for a reason, it doesn't sound anything like popping [] Popping is more like a misfire, it's not something to be concerned about. You simply won't get "det" at idle.
.: Stealth 86 :.
Kodename 47 DJ:
Chad11491 (10-19-2015)
A/C not cold enough Champster BRZ First-Gen (2012+) — General Topics 41 06-16-2015 12:04 AM
How cold did you run your Vortech kit? kaybee123 Forced Induction 8 03-26-2014 10:13 PM
How cold is too cold to seal and wax? Jertronic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-01-2013 12:20 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
it to cold Pekingduck Southern California 9 01-05-2013 09:08 AM
