Drives: Toyota 86
Exhaust too loud need another alternative
Hi all,
Over the course of modding my car Aus 2013 BRZ I installed Namelss headers and KLS overpipe rest of the system stock with ECUTEK. Result bit more power and a tad louder making 169HP To maximize this I decided to go all out and get an SME front pipe and a Greddy Evo 3 exhaust. After changing the front and cat back. Driving the car after install the car was pretty loud. I got home and put the Silencers in and well its better but we all know Silencers restrict back pressure and its still a tad loud for me. So after researching on here and other pages it seems that Invida Q300 may be my solution to just lower the noise to a more stock level again. Anybody have a similar setup and can offer some advice cheers |
#2 |
I went with the HKS quiet front pipe and Perrin resonated cbe. Makes a nice sound, though it is still considerably louder than stock.
#3 |
Slow Learner
Drives: 15 Halo FRS
Why not just put the stock catback back on.?
#4 |
Drives: Toyota 86
Because stock is still restrictive in terms of chasing every HP from N/a
#5 |
Doubt the stock cbe is any more restrictive than the q300
#6 |
Drives: 2013 Black FR-S
No evidence of this.
#7 |
you can also wait and hope that this cat back developed by CSG / ACE is going to get produced:
http://www.ft86club.com/forums/showthread.php?t=95331
| The Following User Says Thank You to ryoma For This Useful Post: | why? (10-11-2015) |
#8 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
Im running stock CBE with a UEL header and E85 and was getting 205whp FOR EXAMPLE: My Stock Catback with the Perrin 4" Tips
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
| The Following User Says Thank You to Aztec For This Useful Post: | Cole (10-11-2015) |
#9 |
Drives: 2015 FR-S (Halo)
I suggest you take advantage of the wealth of knowledge on this site re: exhaust dynamics.
Modern engines like ours do not use backpressure in the exhaust system for power or anything else. It's a question of exhaust capacity and flow rate. A silencer probably does affect exhaust dynamics, but most likely to a negligible extent. For the record, the stock catback is pretty good and there are plenty of people running catless headers/fp/op with stock catback - cross-flow mufflers are quiet. Sent from my SAMSUNG-SM-G925A using Tapatalk
| The Following User Says Thank You to fatalelement For This Useful Post: | Cole (10-11-2015) |
#10 |
Drives: FT86
Stock catback is not restrictive, last dyno day guy with stock catback made most power.
stock catback will be quiter than Q300 put the stock one back on if it too quiet and you dont like the sound then try the q300 |
| The Following 5 Users Say Thank You to steve99 For This Useful Post: | catcha (10-10-2015), Cole (10-11-2015), RustySocket (10-10-2015), Teseo (12-07-2015), wparsons (12-07-2015) |
#11 |
Drives: Toyota 86
Thanks all yes, my assumption is yes stock would be more restrictive. or maybe it was a weight saving thing. either way its a tad too loud for me even with sliencers.
Some good advice and will put the stock one back on and then consider the Q300 |
#12 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Your tune affects your noise as well. Have you been re-tuned since you upgraded your exhaust? You might get more power, and a quieter exhaust.
If I say yes, will that make you think I understand?
#13 |
Drives: Toyota 86
Unfortunately that's a $400 retune gamble i'm not willing to take. Another member had similar setup but with tomei 60s even after retune it was still loud.
#14 |
Drives: Late 2014 Subaru BRZ
The headers would do it. Go FI, that should make it quieter and get rid of the crappy raspy sound that NA gives you.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
| The Following User Says Thank You to GsxrMe For This Useful Post: | catcha (10-10-2015) |
| Loud exhaust / Buddy Club Spec II exhaust help! | chiefshayan | Engine, Exhaust, Transmission | 26 | 12-06-2019 05:59 PM |
| Perrin Exhaust Collar Clamp Replacement or Alternative | Lobstr | Engine, Exhaust, Transmission | 6 | 04-19-2015 06:31 PM |
| How loud is the n1 exhaust? ( in db) | jon2 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-22-2015 03:04 AM |
| My exhaust is loud | mike2100 | Mid-Atlantic | 1 | 08-25-2013 09:13 PM |
| Looking for a loud exhaust | Itssrayyxd | Engine, Exhaust, Transmission | 66 | 04-01-2013 03:53 PM |
