#673 | |
Drives: Toyota 86 GTS
If your AFR is above 12, which it is, you're fine. |
#674 | |
Poor Adult Male
Drives: 2013 Subaru BRZ
Hurr durrr thank you almighty fuel trim overlord I am not worthy
#675 |
Drives: GT86
How you get these logs from your car?
#676 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Tactrix cable or Openflash tablet.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#677 |
Drives: GT86
#678 |
EcuTek? You can yes, I'm just not sure how it works exactly.
95RON SAV Tuned |
#679 |
Drives: GT86
#680 | |
Drives: JAWS
#681 | |
Drives: FT86
you need to use the B01C logcfg.txt file, each time new roms are complied the ram addresses for logging change B00C_B01C_logcfg.txtlooks like your using correct file but some of parameters not logging. you might have to ask some of the other guys on B01C rom if they have sorted out those parameters This sort of thing is why you pay the extra for an OFT :-) as its all sorted for you Last edited by steve99; 10-05-2015 at 08:14 PM. |
#682 |
Drives: FT86
@Joe-G
Try this for B01C if no go try talking to @D-VO type = obd protocolid = 6 ; ISO15765 mode23txaddrwidth = 4 ; mode23 req format info mode23txlenwidth = 1 ; mode23 req format info mode23rxaddrwidth = 0 ; mode23 req format info mode23uds = 1 ; lets OBD channels know you are using mode23 UDS sortpids = 1 ; sort these PIDs by value to potentially make for fewer requests (=faster) calcsampinterval = 1000 ; timing parameter - leave as is - will make default for release version paramname = MAF_Voltage paramid = 0xFFF842AC databits = 16 scalingrpn = x,0.000076293945,* paramname = MAF2 paramid = 0xFFF89118 isfloat = 1 paramname = Throttle_Plate_Open_Angle paramid = 0xFFF89030 isfloat = 1 paramname = RPM paramid = 0xFFF893F8 isfloat = 1 paramname = Engine_Load paramid = 0xFFF8914C isfloat = 1 paramname = Ignition_Advance paramid = 0xFFF8DB88 isfloat = 1 paramname = Defogger paramid = 0xFFF8939F databits = 8 ;offsetbits = 0 ; is KC Learn??? paramname = KC_Advance paramid = 0xFFF8B0C0 isfloat = 1 paramname = Intake_VVT_Adv_Left paramid = 0xFFF8C0EC isfloat = 1 scalingrpn = x,50,- paramname = Exht_VVT_Adv_Left paramid = 0xFFF8C134 isfloat = 1 scalingrpn = x,50,- paramname = FBKC paramid = 0xFFF8B0C4 isfloat = 1 paramname = IAM paramid = 0xFFF816F0 isfloat = 1 paramname = Coolant_Temp (Wrong address all 0's) paramid = 0xFFF8DB70 isfloat = 1 paramname = AFR paramid = 0xFFF89330 isfloat = 1 scalingrpn = x,14.7,* paramname = Speed_Ram paramid = 0xFFF893D0 isfloat = 1 scalingrpn = x,0.621371,* paramname = Ignition_Total_Timing paramid = 0xFFF8AE0C isfloat = 1 paramname = KC_Advance_IAM paramid = 0xFFF8B134 isfloat = 1 ; same as IAT ;paramname = IAT_Ram ;paramid = 0xFFF87C64 ;isfloat = 1 paramname = IAT paramid = 0xFFF8DB8C isfloat = 1 paramname = Throttle Position paramid = 0xFFF8DB94 isfloat = 1 paramname = FLKC paramid = 0xFFF8B160 isfloat = 1 paramname = Fuel_Injector1_Latency paramid = 0xFFF8A05c databits = 8 paramname = Port_Direct_Ratio paramid = 0xFFF8A0F4 isfloat = 1 ;1=OL, not up to temp, 2=CL, 4=OL or decceleration fuel cut, 8=OL due to system ;failure paramname = Fuel_System_Status paramid = 0xFFF8DC0E databits = 8 paramname = IAT paramid = 0xFFF8DBA4 isfloat = 1 scalingrpn = x,1.8,*,32,+ paramname = Coolant_Temp_F paramid = 0xFFF8DB88 isfloat = 1 scalingrpn = x,1.8,*,32,+ |
#683 | |
Canada Eh!
Drives: '13 FRS
http://datazap.me/u/joe-g/20151005?log=0&data= |
#684 | |
Drives: FT86
about 0.2 at idle and increasing with throttle application to about 1.3 maybe try parameters from other B01C file i posted up |
#685 | |
Canada Eh!
Drives: '13 FRS
Thanks again! You've been so much help! EDIT: http://datazap.me/u/joe-g/20151005?log=0&data=9 Last edited by Joe-G; 10-06-2015 at 12:46 AM. |
#686 |
Drives: JAWS
@Wayno @steve99 @Kodename47
here's my newest log with the injector scales, UEL load limits, and my custom maf scale (done with injector scales, but before adding load limits). I'm pretty knock free but it looks to be running too lean compared to commanded. http://datazap.me/u/joshbustos86/jdl...-4-6-7-8-10-13 My custom scale is richer than the stage 1 scale above 3V (where my AFR's were just about spot on without load limits) so I'm now wondering why it's leaner, as I'm not hitting the load limit past 4000 rpm. here's my maf scale (top) vs stg1 (bottom) |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
