Old 10-01-2015, 11:20 PM   #673
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by RavioliG View Post
Hey guys. Today I was noticing that my car was slightly leaner than it usually does.
When trying to understand why through logged data, I found that my LTFT exhibits some funky behavior at WOT.
In my datalog http://datazap.me/u/raviolig/10115?log=0&data=1-8
The 2nd and 3rd pulls cause the LTFTs to creep up to +10.
Like mentioned above, could it be due to an exhaust leak?
I have a trackday next week and just want to make sure my car is 100% beforehand.
I don't know why people who don't know what fuel trims are for are always flipping out over them. They're supposed to be variable, that's what they're for.
If your AFR is above 12, which it is, you're fine.
Old 10-01-2015, 11:24 PM   #674
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
Hurr durrr thank you almighty fuel trim overlord I am not worthy
RavioliG is offline   Reply With Quote
Old 10-05-2015, 11:03 AM   #675
Jonde875
Drives: GT86
How you get these logs from your car?
Jonde875 is offline   Reply With Quote
Old 10-05-2015, 11:11 AM   #676
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Tactrix cable or Openflash tablet.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 10-05-2015, 11:20 AM   #677
Jonde875
Drives: GT86
Can I get it out with ECUTEK Pro Ecu Programming Kit?
I need to send my tuner my logs thats why im asking and I get home from working trip this weekend!
Old 10-05-2015, 11:23 AM   #678
sav
sav's Avatar
EcuTek? You can yes, I'm just not sure how it works exactly.
95RON SAV Tuned
Old 10-05-2015, 11:37 AM   #679
Jonde875
Drives: GT86
Do you know how should I install the wideband gauge (AEM UEGO 30-4110) that my car ECU logs right 0-5V output?
Or correct me if im far a way from right way!
Sorry for off-topic!!
Old 10-05-2015, 02:09 PM   #680
JB86'd
JB86'd's Avatar
Drives: JAWS
I had high LTFT like that when I had a leak at the header/OP connection..like Wayno said your car looks to be running fine, but it wouldn't hurt to test for leaks so you know you're running optimally.
JB86'd is offline   Reply With Quote
Old 10-05-2015, 08:03 PM   #681
steve99
Drives: FT86
Originally Posted by Joe-G View Post
Can anyone take a look at this log? Does it look right?
Using tactrix, and B01C ROM.. Quite new to this. Got the OTS Stg 1 rom flashed, and learning to look at logs, but seems like it may be reading wrong?
EDIT, heres the datazap
http://datazap.me/u/joe-g/reupload?log=0&data=16
the first logcfg.txt file in the tactrix post wont work correctly as its for A00C/A01C roms
you need to use the B01C logcfg.txt file, each time new roms are complied the ram addresses for logging change
B00C_B01C_logcfg.txt
looks like your using correct file but some of parameters not logging.
you might have to ask some of the other guys on B01C rom if they have sorted out those parameters
This sort of thing is why you pay the extra for an OFT :-) as its all sorted for you
Old 10-05-2015, 08:30 PM   #682
steve99
Drives: FT86
@Joe-G
Try this for B01C
if no go try talking to @D-VO
type = obd
protocolid = 6 ; ISO15765
mode23txaddrwidth = 4 ; mode23 req format info
mode23txlenwidth = 1 ; mode23 req format info
mode23rxaddrwidth = 0 ; mode23 req format info
mode23uds = 1 ; lets OBD channels know you are using mode23 UDS
sortpids = 1 ; sort these PIDs by value to potentially make for fewer requests (=faster)
calcsampinterval = 1000 ; timing parameter - leave as is - will make default for release version
paramname = MAF_Voltage
paramid = 0xFFF842AC
databits = 16
scalingrpn = x,0.000076293945,*
paramname = MAF2
paramid = 0xFFF89118
isfloat = 1
paramname = Throttle_Plate_Open_Angle
paramid = 0xFFF89030
isfloat = 1
paramname = RPM
paramid = 0xFFF893F8
isfloat = 1
paramname = Engine_Load
paramid = 0xFFF8914C
isfloat = 1
paramname = Ignition_Advance
paramid = 0xFFF8DB88
isfloat = 1
paramname = Defogger
paramid = 0xFFF8939F
databits = 8
;offsetbits = 0
; is KC Learn???
paramname = KC_Advance
paramid = 0xFFF8B0C0
isfloat = 1
paramname = Intake_VVT_Adv_Left
paramid = 0xFFF8C0EC
isfloat = 1
scalingrpn = x,50,-
paramname = Exht_VVT_Adv_Left
paramid = 0xFFF8C134
isfloat = 1
scalingrpn = x,50,-
paramname = FBKC
paramid = 0xFFF8B0C4
isfloat = 1
paramname = IAM
paramid = 0xFFF816F0
isfloat = 1
paramname = Coolant_Temp (Wrong address all 0's)
paramid = 0xFFF8DB70
isfloat = 1
paramname = AFR
paramid = 0xFFF89330
isfloat = 1
scalingrpn = x,14.7,*
paramname = Speed_Ram
paramid = 0xFFF893D0
isfloat = 1
scalingrpn = x,0.621371,*
paramname = Ignition_Total_Timing
paramid = 0xFFF8AE0C
isfloat = 1
paramname = KC_Advance_IAM
paramid = 0xFFF8B134
isfloat = 1
; same as IAT
;paramname = IAT_Ram
;paramid = 0xFFF87C64
;isfloat = 1
paramname = IAT
paramid = 0xFFF8DB8C
isfloat = 1
paramname = Throttle Position
paramid = 0xFFF8DB94
isfloat = 1
paramname = FLKC
paramid = 0xFFF8B160
isfloat = 1
paramname = Fuel_Injector1_Latency
paramid = 0xFFF8A05c
databits = 8
paramname = Port_Direct_Ratio
paramid = 0xFFF8A0F4
isfloat = 1
;1=OL, not up to temp, 2=CL, 4=OL or decceleration fuel cut, 8=OL due to system ;failure
paramname = Fuel_System_Status
paramid = 0xFFF8DC0E
databits = 8
paramname = IAT
paramid = 0xFFF8DBA4
isfloat = 1
scalingrpn = x,1.8,*,32,+
paramname = Coolant_Temp_F
isfloat = 1
Old 10-05-2015, 09:59 PM   #683
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Thanks for the help. Played around with it a bit, think I got it working :P
http://datazap.me/u/joe-g/20151005?log=0&data=
Joe-G is offline   Reply With Quote
Old 10-05-2015, 10:49 PM   #684
steve99
Drives: FT86
looks a lot better the engine load parameter is wrong it should be values between 0 and about 1.3.
about 0.2 at idle and increasing with throttle application to about 1.3
maybe try parameters from other B01C file i posted up
Old 10-05-2015, 11:39 PM   #685
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Looks a lot better. Still have to make some adjustments I guess, but overall it looks like Im on the right track.
Thanks again! You've been so much help!
EDIT: http://datazap.me/u/joe-g/20151005?log=0&data=9
Old 10-07-2015, 12:19 AM   #686
JB86'd
JB86'd's Avatar
Drives: JAWS
@Wayno @steve99 @Kodename47
here's my newest log with the injector scales, UEL load limits, and my custom maf scale (done with injector scales, but before adding load limits). I'm pretty knock free but it looks to be running too lean compared to commanded.
http://datazap.me/u/joshbustos86/jdl...-4-6-7-8-10-13
My custom scale is richer than the stage 1 scale above 3V (where my AFR's were just about spot on without load limits) so I'm now wondering why it's leaner, as I'm not hitting the load limit past 4000 rpm.
here's my maf scale (top) vs stg1 (bottom)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
