Old 09-28-2015, 11:44 AM   #15
wparsons
wparsons's Avatar
Go all stock, and don't consider drilled rotors ever... even for track use.
If the car is purely street driven, there's zero point in going with different pads/rotors.
As for rotor life, I got 100k km's out of mine, with about 30 track days. I'm not hard on brake parts (obviously), but without track use they would've been totally fine still.
flickr
Old 09-28-2015, 06:45 PM   #16
Blizzard
Drives: '13 FR-S Whiteout
I have some used OEM rotors and Hawk quiet slot rotors for sale if you are interested.
Blizzard is offline   Reply With Quote
Old 10-01-2015, 07:44 AM   #17
wil5bart
Drives: '16 BRZ
OEM are good enough. If you want to try a different brand, Carbotech and Hawk pads are good options.
wil5bart is offline   Reply With Quote
Old 10-01-2015, 09:34 AM   #18
DarkSunrise
DarkSunrise's Avatar
If you want a modest upgrade from stock pads for cheap, I'd suggest Stoptech SP pads. Better initial bite than stock and will hold up to heat better, at the expense of a little more noise and brake dust.
If that's what you're looking for (and not everyone is), they're reasonably priced at about $100/set.
2022 BRZ Build
2013 FR-S Build
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 09:22 PM
Brake Rotor Runout gdrider77 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-20-2015 12:43 PM
Seized brake rotor removal tool fstlane DIY (Do-It-Yourself) Guides 15 09-06-2015 12:38 AM
R1 Concepts rotor, and brake pads ExtremeAutowerks Brakes, Suspension, Chassis 37 12-23-2013 02:39 PM
