Old 09-30-2015, 01:35 AM   #15
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by HachiEnam View Post
I know!!! I actually made a post asking for sound clips with only Headers with or without OP. I'm getting used to the sound. I was just in shock I guess (also my rear seats were down).
I have no regrets, the sound is great, I'm just a bit worried. It's all a learning experience anyways .
If you do get tired of the drone/sound. I can provide sound clips from my setup
I'm running only UEL headers with an inlet hose and a perrin CAI.
I would also look into the cold start fix that Steve has in his OFT tips and tricks. It's extremely nice in the mornings and my exhaust is not loud at all, couldn't imagine yours :p
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following User Says Thank You to Aztec For This Useful Post:
HachiEnam (09-30-2015)
Old 09-30-2015, 01:41 AM   #16
HachiEnam
UCSB!!!
HachiEnam's Avatar
Drives: 2017 GTI sport
Pretty sure my car isnt that bad. I just whine a lot
If you have some sound clips and don't mind sharing it with the internet can you post it here?
http://www.ft86club.com/forums/showthread.php?t=95251
I was trying to make a compilation for noobs like me
HachiEnam is offline   Reply With Quote
Old 09-30-2015, 01:46 AM   #17
HachiEnam
UCSB!!!
HachiEnam's Avatar
@steve99 For the overpipe issue, is it okay if I leave as is for now or will there be long term problems?
Old 09-30-2015, 02:40 AM   #18
steve99
Drives: FT86
If the ltft are less than 10% it either isnt leaking or very small leak not effecting thinks.
if it just rattling on subframe of car its unlikely to anything worse than chip the paint, just touch it up when you fix it.
Old 09-30-2015, 02:45 AM   #19
steve99
Drives: FT86
Oh thank you! I've been smelling some petrol but I am catless, but I havent popped up the hood. Whats a normal LTFT?
if your smelling petrol at the exhaust exit it usually means car is running rich. This can be caused by exhaust leak, the o2 sensor see fresh air with lots of oxygen, it thinks your running lean so ecu adds fuel to try to correct the perceived lean condition, you will usually see high ltft if this is happening like over 10%.
you will smell fuel as startup as the startup routine add a crapload of fuel to heat cats up quick, unless you tune is modded to remove that feature.
Old 09-30-2015, 05:33 PM   #20
HachiEnam
UCSB!!!
HachiEnam's Avatar
@steve99
Do you mind checking my datalog?
This is 2nd gear pull. First time logging so let me know if i did something wrong.
When I completely let off the throttle and at idle, my LFTF is at -7.8. Which means I'm running lean, since I'm cutting 7.8% of fuel?
Let me know what you think
http://www.datazap.me/u/oliveruthio/...g=0&data=1-4-8
Edit: I can't smell my engine bay. Got hit hard by allergies today.
Old 09-30-2015, 06:09 PM   #21
steve99
Drives: FT86
@steve99
looks ok although the log does not show idle,
but ltft of -7 at idle is pretty normal it will vary due changing intake air temps
ltft positive or negitive does not mean its running rich/lean it means the maf scaling is out a bit and the ecu is correcting using fuel trims to get the requested afr.
have a read of the maf scale link below
Your car looks like it runs on the rich side but not badly, this is likely just maf scaling error due variation in maf sensors
looks ok to me, does not appear to have a bad exhaust leak.
Old 09-30-2015, 09:16 PM   #22
HachiEnam
UCSB!!!
HachiEnam's Avatar
That's great news! Thank you
Edit: Turns out it was -0.78% and I'm just blind.
Old 12-14-2015, 03:30 PM   #23
HachiEnam
UCSB!!!
HachiEnam's Avatar
check the overpipe is not hitting the chassis its a very common issue, you can sometime fix it by drillind a new hole in the front pipe mounting bracket above the original and using nut\bolt so the front pipe sits closer to the car underbody ,this then lifts the overpipe slightly as it often hits on underside of overpipe.
So with finals out of the way, I was able to go back home and return to the shop. It turns out the headers were the culprit. The flange of the headers were banging against the skid plate. Now we're looking out for options on how to fix it. I'm considering cutting up the skid plate.
Sent from my Nexus 5X using Tapatalk
Old 12-14-2015, 05:05 PM   #24
steve99
Drives: FT86
you might be able to just dent the skid plate rarther than cut it
Old 12-14-2015, 05:52 PM   #25
HachiEnam
UCSB!!!
HachiEnam's Avatar
Are there any pros/ cons between doing either of them.
Old 12-15-2015, 05:47 AM   #26
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm more than sure it is the exhaust. I've had an inlet tube installed for a couple months not, but thank you for helping .
Isnt the tsudo catback resonated? It looks like it. This is the catback I have:
http://www.ft86club.com/forums/showthread.php?t=25062
I have stock FP ofc
Thank god you didnt get this one or drone would've killed you:
That legit is a dual exit muffler delete, that plus uels would've been killer
FS: Tsudo Catback Exhaust (Titanium tips) urabus Engine, Exhaust, Bolt-Ons 2 04-21-2019 08:50 AM
TSUDO CATBACK EXHAUST FOR SALE frstn Engine, Exhaust, Bolt-Ons 12 05-03-2014 12:03 AM
SOLD Tsudo Catback Exhaust johnb831 Engine, Exhaust, Bolt-Ons 7 12-08-2013 05:03 PM
Tsudo high flow cat and Tsudo Catback Exhaust ERZperformance Engine, Exhaust, Transmission 5 04-23-2013 02:25 PM
Tsudo high flow cat and Tsudo Catback Exhaust ERZperformance Engine, Exhaust, Bolt-Ons 18 03-21-2013 04:35 PM
