Old 09-29-2015, 06:23 PM   #29
justinsstang
Also what radiator should I upgrade to. My girlfriend got her promotion supposedly (not official yet) so I might as well just upgrade them and do it right the first time and have it ready before the turbo kit. I'd rather not, but I don't want to deal with any bs down the road because of cheaping out.
I have a shop that sells their own turbo kit that said they will make me a custom turbo setup with the AVO turbo mounting location (by the trans, out of the engine bay) for $3400. Is this something I should do, or should I just upgrade the oil cooler, radiator, and get a used SBD kit
justinsstang is offline   Reply With Quote
Old 09-29-2015, 07:59 PM   #30
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by justinsstang View Post
Is this the oil cooler you have?
http://www.racerpartswholesale.com/p...olers2#reviews
What else would I need to make it work?
Yes. You will need lines and a thermostatic sandwich plate.
Do not upgrade your radiator. No radiator has been proven to work better than stock.
The Following User Says Thank You to sw20kosh For This Useful Post:
ck-GT86 (09-30-2015)
Old 09-29-2015, 08:23 PM   #31
justinsstang
I'll need a whatty who?
Old 09-29-2015, 09:04 PM   #32
CSG Mike
CSG Mike's Avatar
Originally Posted by The Racers Line View Post
He has had more of a engine bay "melting" issue.
You mean liquifying as a result of rapid oxidation?
shayangh (10-02-2015), The Racers Line (09-29-2015)
Old 09-29-2015, 10:53 PM   #33
sw20kosh
Lol in that case I would just order a Jackson Racing Oil Cooler kit which uses a 15 row series 9 cooler and has been thoroughly track tested by CSG. @CSG Mike
If you end up outgrowing the 15 row you can upgrade just the core to a 20 row or a 25 row.
Old 09-30-2015, 12:01 AM   #34
justinsstang
Well I'd rather go big and save money down the road. Just don't know what that is currently or which one to get. Really not sure where to even mount the oil cooler, in front of the radiator?
You should make a kick ass write up on what all to get for what you used! =D sounds like its what a lot of people need
Old 09-30-2015, 12:03 AM   #35
justinsstang
Also, with a under hood turbo, wouldn't those hood vents all but solve the heating issues? I don't like how they look but they're huge and have to let a lot of heat rise out
Old 09-30-2015, 08:52 AM   #36
Yoda
Drives: Crystal Black BRZ(Sophia)
If its a good shop then that sounds like a steal. Just make sure that the turbo,wastegate and bov they use are good. The rest is just piping.
Yoda is offline   Reply With Quote
Old 10-01-2015, 10:55 PM   #37
boomslang
Drives: Toyota
With Ptuning turbo systems (bottom/rear mount kits) a friend and I both had to run oil coolers that were more than double the size of the standard off the shelf oil cooler (setrab 25 row series 9) in order for the car to not overheat on track.
Did you mount this big Setrab in front of the intercooler or above?
boomslang is offline   Reply With Quote
Old 10-01-2015, 11:36 PM   #38
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Grimmspeed finally made a vented skid plate, for those wondering about things other than vented hoods or oil coolers.
Old 10-02-2015, 02:29 AM   #39
mkivsoopra
Behind
mkivsoopra is offline   Reply With Quote
The Following 3 Users Say Thank You to mkivsoopra For This Useful Post:
CSG Mike (10-02-2015), rb6freak (10-02-2015), sw20kosh (10-02-2015)
Old 10-02-2015, 02:30 AM   #40
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Can you post a link? Not sure I've seen this yet
John Rambo is offline   Reply With Quote
The Following User Says Thank You to John Rambo For This Useful Post:
Old 10-02-2015, 07:33 AM   #41
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
I think he meant Beatrush http://www.ft86club.com/forums/showthread.php?t=95478
Build Thread
Instagram
The Following User Says Thank You to midnight23 For This Useful Post:
BatStig (10-02-2015)
Old 10-02-2015, 08:57 AM   #42
mrk1
Drives: Sterling BRZ Ltd
For every "over heat" thread that pops up on here there should be a second for "had turbo for a long time, no heat issues here"
Larger Capacity Rad, good idea
Oil Cooler since we dont have one, good idea
To me adding the basic coolers is just responsible mods with a turbo. Sure track junkies are seeing heat concerns but people make it out that these cars are the only cars that do that, I have been working around race cars for years and thermal management is always a top priority.
I think people should monitor there data and see where they need to make adjustments other then just tossing money at a "problem" they may not even have.
And maybe that unusually hot day during the summer, take it easy
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
M1K3 (10-02-2015)
Intermittent Over Heating Deep Six Issues | Warranty | Recalls / TSB 6 12-16-2014 09:22 AM
Project Mu 800HC+noise issue after heating up during DD jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-02-2014 02:36 PM
Electronic Heating and AC control in FRS cagster Cosmetic Modification (Interior/Exterior/Lighting) 5 04-08-2013 09:09 AM
