Old 04-07-2013, 11:25 AM   #1
cagster
cagster's Avatar
Drives: Hot Lava Scion FRS
Electronic Heating and AC control in FRS
Ok, techies, is it as simple as swapping out the ac/heat control panel for a BRZ panel, or are there other additions or modifications that need to be made.
Thanks for any ideas.
cagster is offline   Reply With Quote
Old 04-07-2013, 12:31 PM   #2
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Search. It's not a simple swap by any means. If you wanted the automatic climate control you should have bought a BRZ Limited.
Subie is offline   Reply With Quote
Old 04-07-2013, 12:48 PM   #3
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
take a life size picture of the BRZ center control, print it and stick onto your control panel. Cut some holes so you can access your HVAC buttons. Pretend it's the BRZ controls. Win.
chenshuo is offline   Reply With Quote
Old 04-07-2013, 12:58 PM   #4
calis5nest
calis5nest's Avatar
Drives: scion frs firestorm
Not easy but Im sure not impossible
http://www.ft86club.com/forums/showt...+control+panel
-Alan
calis5nest is offline   Reply With Quote
Old 04-08-2013, 07:08 AM   #5
cagster
cagster's Avatar
Thanks Allan. Did a search but didnt find that thread. Thanks for the guidance.
Chuck
Old 04-08-2013, 09:09 AM   #6
Sco2355
Wish it was that simple. Hopefully someone is going to attempt it soon. We are finding with the fogs that there are wires fully ran, just terminated just short of the fogs. So hopefully it won't be too much to hook it up like the fogs.
I know once the 10th anniversary comes out I'll be attempting it because I can get the parts cheaper than the BRZ ones.
Sco2355 is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Electronic Driving Aids trackmagic Scion FR-S / Toyota 86 GT86 General Forum 20 03-07-2013 07:45 PM
Electronic or Cable-driven? mswhong Engine, Exhaust, Transmission 2 12-27-2012 07:59 PM
Electronic Throttle Issue FRiSson Issues | Warranty | Recalls / TSB 0 09-28-2012 10:35 AM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
