Old 08-25-2014, 01:55 AM   #1
jflogerzi
jflogerzi's Avatar
Project Mu 800HC+noise issue after heating up during DD
I am looking for a way to silence these pads. After driving for 10-15mins in CA temperatures, my pads start to squeal. But if I am at the track pushing hard, the brakes will not squeal. I am thinking of taking them out, clean the calipers, and remove any excess brake dust. I have read that high temperature break grease can help. If so where does this grease need to be applied? Anything else I can do. I have bed these breaks before.
Old 08-25-2014, 08:41 AM   #2
troek
troek's Avatar
Drives: 2012 Toyota 86
grease between the pad, and the shims if you got them, if no shims, just grease the back of the pad where it makes contact with the caliper/pistons. a proper bedding in will silence them for awhile, but it always seems to come back with enough street driving.
Old 08-25-2014, 11:44 AM   #3
jflogerzi
jflogerzi's Avatar
I guess i may need to use stock pads for dd and save the project mu pads for events
2013 Series 10 FRS #553
Old 08-25-2014, 12:51 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
What fluid are you running? I boiled my ATE super blue while trying to bed them properly. They make noise now except under hard braking. Im swapping fluid soon so hopefully it will be fine after that.
Old 08-25-2014, 01:20 PM   #5
pantdino
Drives: Firestorm 2013 FR-S
Probably a good idea
My experience is that track pads also don't stop well when cold on the street.
pantdino is offline   Reply With Quote
Old 08-25-2014, 01:57 PM   #6
wparsons
wparsons's Avatar
The HC800+'s are more of a hybrid pad than a dedicated track pad, they work plenty well when cold on the street.
flickr
Old 08-25-2014, 02:15 PM   #7
What kind of pads were you using? That generally doesn't apply to modern compounds unless you're using a pad specifically designed for a small temperature range (e.g. NASCAR) or endurance racing.
Old 08-25-2014, 08:40 PM   #8
jflogerzi
jflogerzi's Avatar
I will deal with the noise. Stopping power has not changed. This weekend i will try and take off the pads etc and see whats up
Old 08-25-2014, 10:04 PM   #9
mfbmike
Drives: 2013 FRS, 2008 R32
Sub'd.
My HC+ 800's squeal a bit under light braking pressure as well.
mfbmike is offline   Reply With Quote
Old 08-25-2014, 10:27 PM   #10
jflogerzi
jflogerzi's Avatar
Originally Posted by mfbmike View Post
Sub'd.
Keep you posted
Old 08-31-2014, 11:33 AM   #11
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I'm currently using these on the street and they squeal, lightly but they squeal and the dust is pretty bad, at least to me. I put them on a week before my track event and as mentioned even cold they bite hard, initial bite is easy and then just claws the rotor, modulation isn't easy. I don't recommend them for daily driving if you're conscious of dust or noise. These are all subjective observations.
yomny is offline   Reply With Quote
Old 08-31-2014, 08:26 PM   #12
troek
troek's Avatar
I have the hc-cs which is the same compound i believe, i think pedal control is extremely linear. So far they seem to be pretty easy on my rotors too(dixcel).
Old 08-31-2014, 08:46 PM   #13
yomny
yomny's Avatar
Not sure about that, I press the pedal and they stab the rotor. I'll have to see at the track. Seem to be a good track pad though.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
Old 09-01-2014, 01:23 AM   #14
troek
troek's Avatar
Dust is bad with any performance pad i suppose. How well did u bed them in? These are significantly harder to bed in than other pads ive had. (This is all assuming the hc-cs and 800hc are the same or very similar. 800hc is their pad for non jdm vehicles.)
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 10:14 PM
Window Regulator Mounting Bolts - Noise Issue & Part Revision? PollosHermanos Issues | Warranty | Recalls / TSB 1 03-06-2014 10:39 AM
No Issue/Noise on BRZ European Models? Trap63 Issues | Warranty | Recalls / TSB 15 09-04-2013 03:29 PM
Electronic Heating and AC control in FRS cagster Cosmetic Modification (Interior/Exterior/Lighting) 5 04-08-2013 09:09 AM
