Old 09-23-2015, 06:17 PM   #617
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
Search Reimax oil pump gears on google and I'm sure you'll find what you're looking for. I'll probably be selling my Reimax pump and RacerX sump soon as I am going dry sump.
Nigelr32 is offline   Reply With Quote
Old 09-23-2015, 06:19 PM   #618
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Originally Posted by Nigelr32 View Post
I have a Reimax pump and have done a comparison of that and the stock pump over gt86.org.uk. From memory, the Reimax pump will flow around 5litres more oil than stock at around 6000rpm.
Remember, the Reimsx pump is also billet, stock is sintered.
I originally dug up the math on the volume difference from your post over on that forum.. Think I linked your thread in my original post suggesting it. That's what got me interested in the pump in the first place, that and knowing Element had limited success with a slightly higher volume pump (the FA20DIT pump).
I bought one, verified the math, concluded the volume should be significantly higher than both pumps, and sent it to Element tuning to test on their race car. Haven't heard back yet.
Did you ever get a running engine / data logged comparison after installing the Reimax pump?
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 09-23-2015, 06:20 PM   #619
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I think I am misunderstanding, are you talking about higher flow from just the gears, or an entire new pump?
Luckrider is offline   Reply With Quote
Old 09-23-2015, 07:41 PM   #620
Nigelr32
The Reimax pump is only the gears, the stock casing is used.
Old 09-23-2015, 08:36 PM   #621
Luckrider
Luckrider's Avatar
Thanks. The product descriptions I've seen make no mention of the increased oil flow. They simply talk about the strength benefit like the factory one is going to explode.
Old 09-26-2015, 03:59 PM   #622
Nigelr32
Just reading through the last couple of pages on this thread, and thought I'd post this..
Some talk of head restrictions to get more oil to the crank. Subaru have already done this with the holes in the rocker posts. Early engines have massive holes in the right bank of tappets, whereas later engines have smaller holes in all 16 rocker posts. I don't remember the actual size differences, but it's quite big when considering area.
The Following 4 Users Say Thank You to Nigelr32 For This Useful Post:
BatStig (09-27-2015), Calum (09-26-2015), Spartarus (09-26-2015), Ultramaroon (09-26-2015)
Old 09-26-2015, 04:32 PM   #623
Do we know when they updated? Serial numbers?
Old 09-26-2015, 04:39 PM   #624
Calum
That Guy
Drives: 2013 asphalt FRS MT
So my early 2012 car is likely fucked. roger
Old 09-26-2015, 06:55 PM   #625
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
PM him. He still logs on.
Old 09-27-2015, 04:24 PM   #626
Nigelr32
No way. I have no idea when the change was made, I just noticed the difference on a rebuild of my 2012 engine. I believe there were issues with the cam timing? This may be something to do with it??
I have a 2012 and a 2014, this is how I found the difference. The earlier engines have a different part no for left and right rocker posts, later they're the same.
Heres a pic of the left and right next to each other..
The Following 7 Users Say Thank You to Nigelr32 For This Useful Post:
AJPG (09-27-2015), BatStig (09-27-2015), Calum (09-27-2015), civicdrivr (09-28-2015), hmong337 (09-30-2015), RavioliG (09-01-2017), sato (09-27-2015)
Old 09-27-2015, 06:42 PM   #627
Calum
That Guy
You wouldn't happen to have the part number for the correct part? I'd like to order a set so I can update the one side when I pull the engine to adjust the valve lash. It would also be really good info to have available.
Thanks by the way.
Also, is it just me, or are those holes huge for the given purpose?
Old 09-28-2015, 02:41 PM   #628
Nigelr32
Thanks by the way.
Sorry, I don't have the part numbers. Before changing anything, you might want to check the timing gears haven't changed to suit the different pressure in that are.. I doubt it, but you might want to be sure first??
The Following User Says Thank You to Nigelr32 For This Useful Post:
Calum (09-28-2015)
Old 09-28-2015, 03:09 PM   #629
Calum
That Guy
Good point, I'll keep that in mind for sure.
Old 09-30-2015, 06:49 PM   #630
Spartarus
...Just add nauseum
Spartarus's Avatar
I see your misunderstanding. It's a gear type pump. If you look up positive displacement gear pump you can find a few helpful animations to explain it. The gear doesn't turn the pump, the gear IS the pump. Well, it is the guts of the pump. The gear and outer ring are the part that actually moves the oil. These gears form a bigger pocket, moving more oil per rev.
-Spartarus
The Following User Says Thank You to Spartarus For This Useful Post:
Hawk77FT (09-30-2015)
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 03:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 06:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 01:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-18-2013 12:24 AM
