Drives: Ultramarine FR-S
Disable turn signal light when not blinking?
Hey everybody! I was wondering if there was a way to disable the turn signal light, making it only light up when you use the left and right blinker.
Basically I want it to always work like it does during the day with all the lighting off. Any suggestions? |
#2 |
wait... what? the green arrow on the dash? or the one on the exterior of your car? both of them should only light up when the signal is activated...
#3 |
A Demon
Drives: Raven GT86
He wants to disable the drl not the signal. I think there's a way to do it with electrical tape on one of the terminals to block the connection. Maybe someone who's done it can chime in
When you turn on your turn lights your signal lights up as well he wants to disable this and only wants the bulb to flash when signal is on not be on when he turns his headlights on Sent from my iPhone using Tapatalk |
#4 |
[insert cool phrase here]
Drives: BRZ Premium
Wut? Do you mean the daylight driving lights? Or the fender side marker?
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#5 |
Drives: 2013 Scion FRS
I think he's talking about is when you turn the headlight switch once the both turn signal lights on the outside come on and he wants to disable that.
If that's the case the only way I know of is to cut the wire at the harness that controls the parking light ( I don't know if that's. actually what's called ) circuit. If someone knows of another way that's less destructive fill free to post it.
#6 | |
#7 |
#8 |
#9 |
Any other method to do this without getting new bulbs?
Sent from my SM-G925V using Tapatalk |
#10 | |
Nick C.
#11 |
#12 |
Drives: 2015 Series.Blue
Keep in mind you're disabling the parking lights and it likely wouldn't pass inspection because of this...
#13 |
Drives: 87 Supra, 13 FRS, 05 FXT
No need to cut any wires, take the plug which the bulbs are plugged into, locate the green wire, take apart the plug and remove the green wire (pin) and fold the wire back into the loom. Put everything back together, and it should only come on when signals are used. That way it is reversible, without having to use connectors.
#14 |
I think you could also simply put a 7440 Amber bulb in to do the same thing. If it doesn't light, bend the pins back around the bulb.
...but like I said, you're no longer legal as you don't have parking lights. |
| Integrated turn signal and puddle light mirror cap | MemphisR | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 09-19-2020 06:25 AM |
| FS: OEM Fog Light Bezel, OEM Turn Signal Housings, and OEM Reverse Light Assembly | zeal86 | Exterior Parts (Aero, Lighting, Etc.) | 15 | 05-29-2016 10:01 PM |
| Turn Signal / Corner Light DRL Question | J_McElwee | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-18-2015 11:25 AM |
| Disable Turn Signal DRL? | 636 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-14-2014 08:09 AM |
| Front turn signal and Parking Light Help! | Cal3000 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-31-2013 02:30 AM |
