Old 09-24-2015, 12:48 AM   #1
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
Disable turn signal light when not blinking?
Hey everybody! I was wondering if there was a way to disable the turn signal light, making it only light up when you use the left and right blinker.
Basically I want it to always work like it does during the day with all the lighting off. Any suggestions?
Avo1789 is offline   Reply With Quote
Old 09-24-2015, 12:58 AM   #2
ryoma
ryoma's Avatar
wait... what? the green arrow on the dash? or the one on the exterior of your car? both of them should only light up when the signal is activated...
Old 09-24-2015, 01:20 AM   #3
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
He wants to disable the drl not the signal. I think there's a way to do it with electrical tape on one of the terminals to block the connection. Maybe someone who's done it can chime in
When you turn on your turn lights your signal lights up as well he wants to disable this and only wants the bulb to flash when signal is on not be on when he turns his headlights on
Old 09-24-2015, 01:21 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Wut? Do you mean the daylight driving lights? Or the fender side marker?
Old 09-24-2015, 01:32 AM   #5
Silent_Dan
Drives: 2013 Scion FRS
I think he's talking about is when you turn the headlight switch once the both turn signal lights on the outside come on and he wants to disable that.
If that's the case the only way I know of is to cut the wire at the harness that controls the parking light ( I don't know if that's. actually what's called ) circuit.
If someone knows of another way that's less destructive fill free to post it.
Silent_Dan is offline   Reply With Quote
Old 09-24-2015, 02:18 AM   #6
KI_ZN6
KI_ZN6's Avatar
We carry single filament LED bulbs that would retain the turn signal feature and the marker light function will be disabled. Feel free to e-mail us for assistance.
KI_ZN6 is offline   Reply With Quote
Old 09-24-2015, 02:27 AM   #7
Avo1789
Avo1789's Avatar
Exactly what I was looking for!
Old 09-24-2015, 02:31 AM   #8
KI_ZN6
KI_ZN6's Avatar
You can shop any front turn signal LEDs from our website and you can simply let us know that you would like single filament and we will send you the proper LED bulbs with the marker light function disabled.
Old 09-24-2015, 02:57 AM   #9
Avo1789
Avo1789's Avatar
Any other method to do this without getting new bulbs?
Sent from my SM-G925V using Tapatalk
Old 09-24-2015, 02:50 PM   #10
Diode Dynamics
Diode Dynamics's Avatar
You could cut the running light wiring out and just leave the turn signal wiring intact
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Avo1789 (09-25-2015)
Old 09-25-2015, 01:29 AM   #11
Avo1789
Avo1789's Avatar
Nick C.
Awesome! I will take a look at the wiring this weekend and hopefully cut the right wire!
Old 09-25-2015, 01:17 PM   #12
Poodles
Drives: 2015 Series.Blue
Keep in mind you're disabling the parking lights and it likely wouldn't pass inspection because of this...
Old 09-25-2015, 11:02 PM   #13
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
No need to cut any wires, take the plug which the bulbs are plugged into, locate the green wire, take apart the plug and remove the green wire (pin) and fold the wire back into the loom. Put everything back together, and it should only come on when signals are used. That way it is reversible, without having to use connectors.
thatfilipinoguy is offline   Reply With Quote
Old 09-26-2015, 07:09 PM   #14
Poodles
I think you could also simply put a 7440 Amber bulb in to do the same thing. If it doesn't light, bend the pins back around the bulb.
...but like I said, you're no longer legal as you don't have parking lights.
Integrated turn signal and puddle light mirror cap MemphisR Cosmetic Modification (Interior/Exterior/Lighting) 52 09-19-2020 06:25 AM
FS: OEM Fog Light Bezel, OEM Turn Signal Housings, and OEM Reverse Light Assembly zeal86 Exterior Parts (Aero, Lighting, Etc.) 15 05-29-2016 10:01 PM
Turn Signal / Corner Light DRL Question J_McElwee Scion FR-S / Toyota 86 GT86 General Forum 1 06-18-2015 11:25 AM
Disable Turn Signal DRL? 636 Cosmetic Modification (Interior/Exterior/Lighting) 10 09-14-2014 08:09 AM
Front turn signal and Parking Light Help! Cal3000 Cosmetic Modification (Interior/Exterior/Lighting) 2 10-31-2013 02:30 AM
