Old 09-20-2015, 01:11 PM   #29
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Not true. The equipment they have now can square up the bracing (there is no "frame") as good or even better than new. The single determining factor between write off and repair is cost.
True story. When mine was fixed up after its accident, damage was about 10k. Drives just as good as it ever did, and I've put maybe 12 hard track days on it since. Even my HPDE instructor mentioned it felt just as solid as his two month old car. It did take about 8 weeks to fix, but they ordered all oem parts from Subaru save for the AC condenser (which works waaaaay better than stock did) because the car was only out for four months or so at the time.
Quality of the parts used and skill of the repair shop make all the difference.
I was really upset at first because the car was so new, but I bought it with the intention of driving it till it comes apart then putting it back together stronger anyway. If not on the road it would have eventually happened on the track. I'm just grateful the 10k didn't come out of my pocket for that one haha
Sent from my LGLS990 using Tapatalk
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
The Following User Says Thank You to Xinshadow For This Useful Post:
Tcoat (09-20-2015)
Old 09-20-2015, 06:37 PM   #30
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by Cohenology View Post
Would the fact I was able to drive it home make it any more less likely there is frame damage?
No. You can often drive a car with frame damage.
Total windshield washer amt? SteveGrillo BRZ First-Gen (2012+) — General Topics 21 03-04-2022 10:21 AM
Total Noob Questions Rifle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2015 05:27 AM
Total lost BlackJesus Scion FR-S / Toyota 86 GT86 General Forum 66 07-12-2015 11:04 PM
Let's give $1 to the first total'd FRS owner miata Scion FR-S / Toyota 86 GT86 General Forum 55 01-06-2012 11:00 AM
