Old 09-13-2015, 08:04 PM   #1
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Alignment of steering wheel changes....
So a strange issue. 90% of the time I drive the steering wheel is at the 1 o'clock position and the other 10% it is straight like it should be. I can't find a reason that it changes. I did curb the car badly and then had it aligned again. Since then the issue has been this way. When I rotated the tires I noticed they are wearing more heavily on the front insides. I am running the car low and with camber plates and bump steer Whiteline products in the front. Help please. Name:  ImageUploadedByTapatalk1442185371.039873.jpg
DrDuquette is offline   Reply With Quote
Old 09-13-2015, 08:41 PM   #2
ryoma
ryoma's Avatar
how are the roads that you are driving on? some roads are not perfectly flat and you will have to compensate for it. how are your suspension components, mainly tierods and balljoints? are you sure they have not been damaged in your impact with the curb? although you might have gotten an alignment, there might have been damage such as bending on the tierods that the alignment shop might have not caught. also make sure that the alignment shop tightened the lock nuts on your tie rods.
if your tires are wearing heavily on the inside, that most likely means you are running a lot of negative camber. if you get a wavy pattern (up and down), then you might have blown shocks. if you notice feathering, then your toe is out of spec
The Following User Says Thank You to ryoma For This Useful Post:
DrDuquette (09-14-2015)
Old 09-13-2015, 11:15 PM   #3
I recommend you take it in to an alignment shop, let them figure it out.
Old 09-13-2015, 11:54 PM   #4
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Did you notice this before or after your alignment? Chances are that your alignment shop set up your alignment "straight" but did not compensate for road crowning ( roads are typically not completely flat to allow for drainage). Take it back to your alignment shop, they should be able to fix that in 10 mins.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 09-14-2015, 03:04 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
110% that alignment shop did jack shit.
The fact your insides are worn out means just that. I would tell the mechanic about your camber plates, that way they can work with it.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 09-14-2015, 10:49 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
If they didn't notice and didn't ask I'd run far away. Take it to a dedicated performance shop. It cost more but worth it every time.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 09-14-2015, 11:55 AM   #7
DrDuquette
DrDuquette's Avatar
Thanks. I will do all that. I want it right before my new wheels/tires are put on. Anyone recommend a shop in the Bay Area? North Bay or Sacramento?
Old 09-14-2015, 12:51 PM   #8
BigFatFlip
BigFatFlip's Avatar
Try searching around the norcal subforum, I'm in the east bay, so not too familiar in that area.
Tyre/Wheel rotation and wheel alignment for the 86? FT_86_SM_GP AFRICA 17 11-05-2015 05:01 PM
Which shop can zero the steering angle sensor and yaw sensors after alignment? krayzie CANADA 5 09-09-2015 07:28 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 01:15 AM
Crook steering after getting alignment Maverickgear Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-29-2014 04:45 AM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-21-2013 12:45 AM
