Old 06-02-2012, 09:53 PM   #57
Lytheum
Drives: 2013 BRZ Premium 6MT
im glad you can still disable vsc with no sensors! i really dont want to spend money for sensors with snow tires. i also want to be able to slide around in the winter without computers killing my fun lol
Lytheum is offline   Reply With Quote
Old 06-03-2012, 04:10 AM   #58
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
Take the original sensors. Bust down the spare, Tape them inside the spare tire. Reseat the tire and inflate, then put the spare back in the trunk. This should trick it.
Or do this
http://www.clublexus.com/forums/is-s...pipe-bomb.html
Never tried it but people tell me it works.
Ishii
Ishii Motors is offline   Reply With Quote
Old 06-03-2012, 09:06 AM   #59
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Or do this
Ishii
That probably won't work with the BRZ/FRS. The sensors are triggered to transmit by the rotation of the wheel. But if someone tries it and it does work post it on here.
Old 06-03-2012, 10:32 AM   #60
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by dsgerbc View Post
Sadly, I was wrong. The light came on after ~30 miles of non-stop highway driving. VSC off engages like before, however.
So tcs/vsc can still be defeated 100%? I can ignore the light
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-04-2012, 01:50 AM   #61
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I left sensors in my stock wheels when I installed my Rotas onto my FR-S and my TMPS light eventually came on. Traction control is not affected. Light flashes for a short time and then stays on solid. I'm going to attempt to remove the bulb in the cluster tomorrow and if I can do it I will post instructions.
Old 06-04-2012, 11:58 AM   #62
YukiHachiRoku
Lex Luger
YukiHachiRoku's Avatar
Drives: 2004 GS430
doh
YukiHachiRoku is offline   Reply With Quote
Old 06-06-2012, 06:57 AM   #63
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Hey ! I've run no TPMS last night and this morning?
NO TIRE LIGHT
It came up after like 20km last night and was on all the the time I'll run it. But this morning no light at all. Maybe it got the be sure with a long "OFF" key cycle that it really don't have TPMS sensors to not cause conflic with bads sensors.
So yeah, the manual is right! I'll keep you updated!
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 06-06-2012, 07:19 AM   #64
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Okay now that I have my BRZ I've been playing around with TPMS a little this morning and made a few discoveries.
1. The sensors are 315Mhz
2. They are compatable with Toyota TPMS protocals
3. The ECU does not appear to be programmable with the ATEQ quickset tool (latest firmware QD1-44)
I have a ATEQ VT-55 which lets me read the sensors, but not the OBDII attachement that lets you program ECU so I can't say if it would work or not but I doubt it.
I'll be playing around with this a little more later today. I haven't tried every possible Toyota/Scion/Subaru Make/model combination for the Quickset yet. I'm also going to contact ATEQ and ask them about firmware updates to support the BRZ/FR-S.
Edit:
Here are the sensor readings from I was able to get with the VT-55
---- LEFT FRONT ----
Sensor ID : ID: 1295AE
Pressure : 35.4 PSI
Temperature : 60 F
Sensor state: WAKE
---- RIGHT FRONT ----
Sensor ID : ID: 12952D
Pressure : 35.4 PSI
Temperature : 62 F
Sensor state: WAKE
---- RIGHT REAR ----
Sensor ID : ID: 12952C
Pressure : 34.4 PSI
Temperature : 57 F
Sensor state: WAKE
---- LEFT REAR ----
Sensor ID : ID: 129524
Pressure : 33.9 PSI
Temperature : 60 F
Sensor state: WAKE
FWIW I had a meeting yesterday with the rep from ATEQ (I work in the aftermarket) and he was well aware of the FRS/BRZ and said they'll have an update shortly. He also is building a 2011 WRX with his son so he is a big fan of the twins.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 06-06-2012, 08:15 AM   #65
atledreier
Drives: GT86 DGM
You can read tiretemps? Is that airtemp or what?
atledreier is offline   Reply With Quote
Old 06-06-2012, 08:34 AM   #66
#87
I usually post drunk
#87's Avatar
Can you pass inspection with the light on in the dash?
#87 is offline   Reply With Quote
Old 06-06-2012, 08:37 AM   #67
neutron256
neutron256's Avatar
It's the tire temp. To bad the ECU won't display it for us.
Old 06-07-2012, 04:32 AM   #68
atledreier
Drives: GT86 DGM
No, but an OBDII dongle and an iPhone will!
Old 06-07-2012, 10:14 AM   #69
neutron256
neutron256's Avatar
What app are you using? As far as I know OBDII does not output any TPMS data.
Old 06-07-2012, 10:56 AM   #70
mla163
Overthinking it
Drives: BRZ in CS
There was an article on Jalopnik a few months ago that detailed a way to get rid of the TPMS light. I can't find the thread, but the gist is this:
Fabricate a PVC tube with the TPMS sensor on it and a valve stem. Inflate to required pressure. Throw these in the trunk with the spare. Change tires all you want. TPMS reads the proper pressure.
mla163 is offline   Reply With Quote
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
Auto Parking Sensors? Swancoat Scion FR-S / Toyota 86 GT86 General Forum 84 02-18-2012 02:01 AM
