Old 05-30-2012, 07:22 PM   #29
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
TPMS sensors are replaceable, but the big question is what frequencies are the sensors on that allows them to talk with the ECU.
And of course, will we be unable to disable TCS/VSA with the TPMS sensors removed.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-30-2012, 07:37 PM   #30
MTeator
First 86
if my wheels arrive Friday I'll be able to answer that then.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
The Following User Says Thank You to MTeator For This Useful Post:
civicdrivr (05-30-2012)
Old 05-30-2012, 08:01 PM   #31
dsgerbc
Drives: BRZ(sold), STI
Looking through Scion VSC description on TIS right now. I see no references to TPMS.
The Following User Says Thank You to dsgerbc For This Useful Post:
Old 05-30-2012, 08:06 PM   #32
dsgerbc
Originally Posted by Primo86 View Post
I am unsure if this is the case with other German cars let alone Japanese, but I can't imagine it would be that different.
It seems that new sensors will have to be registered with the ECU first.
Primo86 (05-30-2012)
Old 05-30-2012, 08:08 PM   #33
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Frequencies are important but there are only a few different ones that are used. Most common in the US is 315Mhz. Just as important is the protical used which is different for pretty much every manufacturer.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
civicdrivr (05-30-2012), Primo86 (05-30-2012)
Old 06-01-2012, 10:35 AM   #34
neutron256
neutron256's Avatar
Okay now that I have my BRZ I've been playing around with TPMS a little this morning and made a few discoveries.
1. The sensors are 315Mhz
2. They are compatable with Toyota TPMS protocals
3. The ECU does not appear to be programmable with the ATEQ quickset tool (latest firmware QD1-44)
I have a ATEQ VT-55 which lets me read the sensors, but not the OBDII attachement that lets you program ECU so I can't say if it would work or not but I doubt it.
I'll be playing around with this a little more later today. I haven't tried every possible Toyota/Scion/Subaru Make/model combination for the Quickset yet. I'm also going to contact ATEQ and ask them about firmware updates to support the BRZ/FR-S.
Edit:
Here are the sensor readings from I was able to get with the VT-55
---- LEFT FRONT ----
Sensor ID : ID: 1295AE
Pressure : 35.4 PSI
Temperature : 60 F
Sensor state: WAKE
---- RIGHT FRONT ----
Sensor ID : ID: 12952D
Pressure : 35.4 PSI
Temperature : 62 F
Sensor state: WAKE
---- RIGHT REAR ----
Sensor ID : ID: 12952C
Pressure : 34.4 PSI
Temperature : 57 F
Sensor state: WAKE
---- LEFT REAR ----
Sensor ID : ID: 129524
Pressure : 33.9 PSI
Temperature : 60 F
Sensor state: WAKE
The Following 5 Users Say Thank You to neutron256 For This Useful Post:
civicdrivr (06-01-2012), Fly Guy (06-01-2012), Matt Andrews (06-01-2012), RaceR (06-01-2012), Scooby South (06-05-2012)
Old 06-01-2012, 10:40 AM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
315Mhz according to Tire Rack.
Are you sure we are unable to disable TCS/VSC? Not all cars do that but I do fear the BRZ might.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 06-01-2012, 01:08 PM   #36
dsgerbc
Thanks. Nice to know that at least the $400+ tool can read those. My outdated and abandoned by manufacturer $150-dollar tool couldn't
Let's hope that ATEQ is quick to update their quickset tool to work with BRZ/FR-S
Do you know what manufacturer protocol those use? Toyota usually uses Pacific and TSW, iirc.
Old 06-01-2012, 01:09 PM   #37
dsgerbc
I pretty much doubt that. I looked though Scion VSC description/repair/diagnostics in TIS and there are zero references to TPMS. I'm probably gonna try a few wheels I have over the week end so I'll know for sure.
Old 06-01-2012, 01:12 PM   #38
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Cool. I wish I had a 5x100 wheel/tire to test with.. sadly no such luck here
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-01-2012, 01:14 PM   #39
dsgerbc
I also have Legacy GT rear pads laying around, and I plan to see if they fit
P.S. You might be able to test it with wheels off and car on jackstands....
Old 06-01-2012, 02:43 PM   #40
neutron256
neutron256's Avatar
No unfourtanatly the with the VT-55 you just select the Manufacturer and it gives you ID, temp, pressure and battery status. It doesn't tell you which protical it received.
I've always wanted the OBDII module but I can't complain for something I got for $200 off eBay. The Quickset is a nice way to bridge the gap, or at least it was in my other cars.
Old 06-01-2012, 03:20 PM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Test those pads ASAP please!!
After posting that I realized the spare likely doesn't have a TPMS sensor so I can just install that on the front and find out :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-01-2012, 09:37 PM   #42
dsgerbc
So I put my Subaru wheels on. Went for a drive. A loooong one, the TPMS light did not come on. Drove some more - light didn't come on. Then I stopped and read the manual. Light does not come on if the system does not sense any sensors.
Naturally, the "vsc-off" button works as normal.
Seems like the answer is no.
I'll post a pic in a few in some thread that might be relevant.
That might be the only way to test the-now-irrelevant question
The Following 5 Users Say Thank You to dsgerbc For This Useful Post:
CoRi J (06-01-2012), Dave-ROR (06-01-2012), Fly Guy (06-01-2012), Klinn (06-02-2012), trueno86power (06-01-2012)
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
Auto Parking Sensors? Swancoat Scion FR-S / Toyota 86 GT86 General Forum 84 02-18-2012 02:01 AM
